OEM USB Port Question
Results 1 to 3 of 3
Thread: OEM USB Port Question
    Greenhorn jpet3's Avatar
    Apr 2017
    PA, USA
    11
    Hey all,
    So I'm shopping for a new stereo setup- I'll be purchasing a new head unit, external amp, full set of speakers and a sub for my 2013 Si. Problem is, I see a lot of head units that say I'd lose the functionality of the stock USB port (inside the console between the front seats). However, most that I've looked at have rear USB ports, which I'm assuming end up inside of the dash behind the receiver / head unit. One of the ones I'm currently looking at comes with a 58" USB extension cable which I /assumed/ was for connecting the factory USB port to it. I wasn't sure that this was a correct assumption, though, and I was really hoping to retain the use of that port. Anyone else replace their stock stereo, and are you still able to use the factory USB port in the console? Any input is appreciated.
    Baned
    Arizona
    8,180
    It has been a few years, but my 2012 Si had a USB port in the center console and I think it was just an extension cable that eventually connected back up to the head unit. If you rip apart the center console and remove it, you'll see a connector on the right (passenger) side right where the center console meets the dashboard. Unplug it and it's like half a USB plug. It might work. Good luck.
    Apr 2017
    PA, USA
    11
    Ah okay, that makes sense. I'll have to take a look and see what I can do. Thanks for the info!
  1. 2 USB damaged using the USB port, what is the correct way to plug/unplug a USB?
    By moonshadow2000 in forum Audio/Video & Navigation
    Last Post: 08-10-2016, 04:59 PM
  2. [HELP] Civic 2012 DX USB port
    By Hazardowz in forum Audio/Video & Navigation
    Last Post: 09-09-2014, 04:05 AM
  3. 2012 Si Sedan USB Port Help
    By createacat1 in forum Audio/Video & Navigation
    Last Post: 11-04-2012, 07:57 AM
  4. Zune HD in USB port
    By bjspack in forum Audio/Video & Navigation
    Last Post: 05-19-2012, 10:56 AM
  5. USB port does not work :(
    By charunkel in forum Audio/Video & Navigation
    Last Post: 07-18-2011, 07:34 AM
