Possible to reach 200 lb-ft of torque without boost? - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 26
Like Tree11Likes
Thread: Possible to reach 200 lb-ft of torque without boost?
    Los Angeles
    147
    im sure 200 is possible with a head swap and some bottom end work.
    -2003 Suzuka Blue S2000
    -2015 Taffeta White SI Sedan CT-E SC
    -2016 Acura ILX
    Supporting Vendor team3d's Avatar
    Oct 2011
    los angeles
    10,437
    I will say 180lbs is possible
    9th gen civic only online store, please visit Hidden Content
    Super Mod's Pet MeeSh's Avatar
    Mar 2015
    Chicago-ish
    622
    Hella JDM claims 175 TQ.. not sure if that's to the wheels or not. I believe he only has CAI, Downpipe and Tune for power. Maybe that same setup with Buddy Club pullies (not sure what these do), RBC swap & lightweight wheels will get up to 190TQ on the top end of RPM range?
    RujoKinJal likes this.
    '15 TW FB6 Si
    Engine
    Rick Spec'd Intensity CAI
    RV6 Catless Downpipe
    Hasport 62a Rear Motor Mount
    Acuity Instruments Short Shifter
    Acuity Instruments Trans Springs
    Stock midpipe and muffler
    Vit Tuned
    Suspension
    Buddy Club Sport Spec Coilover
    24mm Progress RSB
    FKX Shock Bushings
    SPC Camber Arms
    Ingalls Front Camber Bolts
    Moog Endlinks
    Wheels
    Advan RZ 17x8.5 et31
    Michelin Pilot Super Sport 225/45
    Non-Racecar Stuff
    JL Audio 10" Sub
    Alpine 500W Amp
    Instagram: @MishkaCreates | @DankJDM
    Oct 2011
    los angeles
    10,437
    Quote Originally Posted by MeeSh View Post
    torque are much harder to improve on.... i got 170lbs of tq
    Possible to reach 200 lb-ft of torque without boost?-ilx-dyno-11-18-2015.jpg
    Oct 2011
    los angeles
    10,437
    torque are much harder to improve on.... i got 170lbs of tq on my stage 3 power package
    light weight pulley, light weight flywheel, knife edge crank shaft, light weight rotors, light weight tires, light weight wheels are all rotational weight reduction...
    example, run with a heavy, 19oz combat boots and switch to a 8oz nike flynet, which one will make you run faster ? that is same effect with rotational weight reduction... you use less energy to spin/rotate the parts/cars = more power
    Click image for larger version.
Name:	ilx dyno 11-18-2015.jpg
    MeeSh likes this.
    3,791
    The torque rating is not a good way to measure power. BMEP is more accurate. I doubt it will make power then its already rated with out power adders(turbo,etc) and extensive engine work. Honda already is tuned very good and bolt ons dont do much except personalize your vehicle. It might add a pound of torque here and there but its still limited by the engine size and fuel quality(knock) and the percentages would be very small. More fuel equals more heat and more friction which lowers HP. Raising VE by using better fuel lowers the stress on the engine and makes more consistent power by using all the fuel. Here is a better explanation I found. WHY BMEP, WHY NOT JUST TORQUE OR HP?
    team3d likes this.
    Oct 2011
    los angeles
    10,437
    the rule of thumb of how engine makes hp is for every 150cfm the engine flows, it generate 100hp...
    it's why cte supercharger is always average around 300whp because M62 is rated at 460cfm with 10psi boosts
    stock k24z7 engine flows in the ball park of 300cfm (at 7000rpm)... you can make more than 200whp if your able to operate at a higher rpm (8000rpm)
    now, if your able to reduce the load of the engine with parts like light weight pulley, flywheels, rims, tires, rotors... these will free up power.. becuase you now use less energy to move the vehicle
    you can make cars fast without "making power" just like swimmers can swim faster with better suits (speedo LZR)
    Super Mod's Pet
    Loves Park, IL USA
    601
    To make that kind of torque naturally aspirated, you're probably looking at different pistons. Think upwards of 12:1 compression.
    3,791
    And a shot of nitrous.
  12. #20
    18
    I made 202whp and 180wtq in my current setup (custom 3.5" CAI, 3" PLM DP, ported stock mani). But I won't make it 200 wheel tq without f/I
  1. 2013 civic si sedan "To boost, or not to boost?"
    By bactosa in forum Forced Induction And Nitrous
    Last Post: 11-24-2014, 03:25 PM
  2. Spark plugs for boost / MAP sensor for boost
    By UTAH TSX in forum Forced Induction And Nitrous
    Last Post: 01-22-2014, 11:29 PM
