Under the hood right between the air intake filter and relay box
2012 civic si coupe RR
2010 Fusion se
2010 Focus se sold
2008 F-150 xlt
2007 edge se
1999 sentra se-l
1991 F-150 lariet
Noe'
9th Gen PMM Si Sedan
Sik Wit It . . . Since 01
K24Z7 Crew Member # 69
"We walk the same path, but got on different shoes."
There is no reason they should be hooking up their Honda tablet to your car for a routine oil change. Best way to make sure that doesn't happen though is to take it elsewhere for an oil change. Save yourself some money and it would make sure you don't get an overzealous tech updating your ecu.
An ECU has nothing to do with an oil change. If someone tells you otherwise you should avoid them at all costs. If you are referring to the oil life reset, that is set through the iMid, and other cars it is usually reset through the cluster or radio.
2012 Honda Civic Si
Rallye Red Coupe
Navigation
Let me get this strait I have to send them my ecu so they can do it I don't like that at all
Sent from my PC36100 using AutoGuide.com App
So if I buy the reflash from corsport I can't do it myself
correct
2012 SI Sedan PMM
18" BBS RK's
Megan Racing axle back
Road magnet springs
custom K&n sri
P2R TB Spacer
