Battery died, ECU going berserk.
Results 1 to 10 of 11
Like Tree4Likes
Thread: Battery died, ECU going berserk.
    Oklahoma City
    15
    Exclamation Battery died, ECU going berserk.
    Was cleaning and detailing my car when the radio started intermittently going out. Finally it wouldn't come back on, so I decided to start the car. I then realized the battery had died because the car wouldn't start. I had a buddy push me and I popped the clutch which started the car.
    Upon starting the car, I now have several lights on my dash. I have "Check Power Steering System", "Check ABS System", "Check Brake System", and "Check VSA System". I've tried turning the car off and back on. Still same issue.
    Any and all help greatly appreciated. ('12 Civic Si Coupe)
    Big Timer!!! acbers's Avatar
    182
    Quote Originally Posted by okcSi View Post
    Same thing happened to me last weekend. I took the car to autozone and had the codes cleared after having them cleared I was all good to go. I hope this helps
    Oct 2012
    365
    Once the battery is charged up I would try discounting the battery for 5 minutes. Hopefully this works.
    I Like Grits Digger's Avatar
    May 2012
    New Madrid Fault
    9,655
    battery under warranty....take to dealer and replace
    also this The Battery Is Dead and Needs Multiple Jump-Starts 2012
    Electrical system:starter assembly 2012
    '12 TW EX SEDAN
    Click on Following Links for Help:
    Oklahoma City
    15
    I drove around and it cleared. Very weird. I will definitely have the battery replaced under warranty though. Thanks for the quick responses. I love how when I called the dealership, no one would talk to me because it was too late, but I ask on here and you guys are right there for me. Thanks again guys!
    Digger likes this.
    Big Timer!!! cepcivic's Avatar
    Sep 2011
    Millersville, Md.
    205
    The ECU needs 12 volts to work properly!
    RitcheyRch likes this.
    2012 TW EX-L
    Tint
    homemade CAI for now...
    Trunk spoiler
    Factory fogs
    PIAA headlights
    Hi/low note horns
    HF underbody panels
    Hush matted trunk, hood, and floor pans
    painted grill
    blue footwell lighting
    H11 yellow fog light bulbs
    Big Timer!!! oldguy's Avatar
    Phoenix, AZ
    187
    These cars are under unusual electrical strain with all the electric gizmos...steering, i-mid, etc. I have had a BMW motorcycle for years and they (BMW) recommend using a constant battery charger/trickle charger. I use a Battery Tender Jr on my motorcycle, and a Batter Tender Plus for my 13 Civic Si. Batteries have not kept pace with the needs of the modern automobile/motorcycle. We can complain and get nowhere, or we can simply tend to the needs of our new electrical black holes and adapt. Just a thought.
    Digger likes this.
    13 Si Rallye Red Coupe
    POP Crew #36
    New Official K24z7 #324
    K&N air filter
    RED Lloyds all season floor mats (front)
    Nokya headlight and fog light bulbs (Arctic White from Group buy)
    LED Interior lights (ijdmtoy)
    Bluestar's winch!! FooBird's Avatar
    Feb 2012
    Kirkland, WA
    8,713
    Seems like if you drain the battery, all hell breaks loose regardless of it being bad or not. Gotta make the power for all these electronics in the car.
    bluestar gave me the clap.
    K24Z7 Crew Member #11
    HFP Crew Member #11
    2012 Honda Civic Si Coupe - Crystal Black Pearl
    2014 Toyota Tacoma TRD Off-Road - Barcelona Red
    Platinum Member Jamis's Avatar
    NWOH
    1,797
    I had a '92 Saturn SC automatic. If the battery voltage dropped below 10.8 volts, the transmission control unit would lock the transmission in second gear (limp home mode). Found out when one of the rectifier diodes in the alternator puked. No warnings. Thought I had broken the transmission.
    2013 CBP EX-L sedan w/Navi.: K&N Drop In
    33,000 Mi.;Avg MPG:32 city;44 hiway;87 E10;ECON On
    48 mos. old, not a single problem, issue, or recall.
    I've gone out to find myself. If I return before I get back, have me wait for me.
    Old Age & Treachery Trumps Youth & Exuberance.
    52,921 more Civics than Cruzen in '14
    108,782 more Civics than Cruzen in '15
    163,893 more Civics than Cruzen in '16
    Top Dawg!! TheTech's Avatar
    May 2013
    Delaware
    1,060
    the systems you have lights on for whenever your battery dies is a direct result of low battery voltage. with the key on your computer is looking for a given voltage from many different components. if it recieves too little voltage compared to what it feels that it should be seeing (lower than operating perameters permit) it sees an issue and trips a light on. disconnecting your battery for a few minutes does get rid of the lights. You can also do an ecm/pcm reset by removing both battery cables from their terminals ( ground first, (safety first)) and touching them together for roughly 30 seconds. When you reattach them be sure to put the positive on first, then the ground to lessen the likely hood or severity of sparks.. be sure that anytime you disconnect your battery to do an idle speed relearn, let the vehicle sit and idle for 15 minutes. the idle may be higher or less steady than usual otherwise. hope it helps
  1. Battery Tie Down
    By spazerboy in forum Coupe
    Last Post: 01-06-2013, 02:23 PM
  2. Battery Relocation
    By xxxxxxxxxprivman in forum Intakes and TB Spacers
    Last Post: 12-17-2012, 04:42 PM
  3. Macho man Randy Savage died today
    By '06Siguy in forum Water Cooler
    Last Post: 05-20-2011, 09:31 PM
