The Official: Q&A for the CT-E Supercharger Kit - Page 323
Page 323 of 323 FirstFirst ... 223273313321322323
Results 3,221 to 3,229 of 3229
Like Tree943Likes
Thread: The Official: Q&A for the CT-E Supercharger Kit
  1. #3221
    131
    I thought I could get away without using the spacer...no dice. It is needed for clearance. I think the 8th gens got away with it but I did not see how the pulley would clear without it.
  3. #3222
    Los Angeles
    134
    you have to use the spacer if you don't want to slightly bend the line.
    I just bent it out of the way and it clears perfectly fine without the spacer.
    -2003 Suzuka Blue S2000
    -2015 Taffeta White SI Sedan
    -2016 Acura ILX
  4. #3223
    131
    What size pulley are you running? I could not see a way to get the charger onto the manifold with the line in place.
  6. #3224
    1,608
    You make a very valid point. Maybe that's why Vit didn't use the spacer either, his brother had the 2.95 pulley.
    I'll plan to have a shop discharge the AC and I'll install the spacer. (3.6")
    Flashpro (tuned by Vit)
    Hankook Ventus S1 Noble2 245/40-17
    HFP suspension
    Morimoto Elite HID 55w 5500K
    CTE supercharger w/3.6" waiting for install!
    [Full Race catted DP and Full Race exhaust with added Vibrant ultra quiet resonator and Vibrant muffler swap] FOR SALE
  7. #3225
    Los Angeles
    134
    I am using a 3.6" pulley. There are numerous ppl who have installed this without using the AC spacer with a 3.6" pulley by slightly bending the line. If you don't want to bend the line, it is impossible.
    BWill9886 and dpetro1 like this.
    -2016 Acura ILX
  8. #3226
    131
    Did you bend the line with it still attached to the compressor (ie: you did not discharged the ac?)
  9. #3227
    One Bad Mama Jama!!! BWill9886's Avatar
    St. Louis, MO
    318
    That's correct. It doesn't need a ton of persuasion.
    2013 Rallye Red Si Sedan
  10. #3228
    Los Angeles
    134
    yes sir. I just unbolted all the brackets that bolted it to the frame and lightly bend it. It is VERY easy to bend
    -2016 Acura ILX
  11. #3229
    Big Timer!!! MoreRicePlease's Avatar
    Dec 2015
    Los Angeles
    105
    +1 for just slightly bending the line. I'm running the 3.6" pulley, have had it in for about 6 months without any rubbing issues. Didn't need to discharge the AC or anything.
    2012 Civic Si Coupe
    CT-E Stage 1+ supercharger (3.6" pulley; 550cc injectors)
    AEM Cold Air Intake
    Full Race 3" catted downpipe
    Full Race 3" catback exhaust w/ torque solution hangers
    Boomba Racing Motor Mounts
    Progress 24mm rear sway bar w/ Moog endlinks
    Eibach 24mm front sway bar
    Megan Racing strut tower bar
    HFP Suspension
    MB Weapon wheels
    Tuned by Vit Viper!
  1. Replies: 91
    Last Post: 07-29-2016, 03:19 PM
  2. Kraftwerks Supercharger kit
    By FXRob in forum Forced Induction And Nitrous
    Last Post: 07-23-2012, 03:58 AM
  3. OFFICIAL: Rap & Hip-Hop Thread
    By wattskee in forum Water Cooler
    Last Post: 07-16-2012, 03:27 AM
  4. Replies: 22
    Last Post: 01-09-2012, 03:37 PM
