0W20 Brand or Flavour that suits you fine... You may want to use full syn oil if you live in extreme climates. Same thing for brake/clutch fluid. DOT 3 will be fine but, personally, i use Light Viscosity DOT4LV from Pentosin because it really does a better job in the cold temps we see in Canada during Winter! (-20c and colder is typical..)
Marko!
