Factory engine oil and Heavy Duty DOT 3
Results 1 to 10 of 11
Thread: Factory engine oil and Heavy Duty DOT 3
    Oct 2016
    8
    What engine oil does Honda put in at the Factory, for the '12 Civic? And for the '15 Civic? Moly is included also, right?
    And, has Honda stopped shipping their HG Heavy Duty DOT 3 Brake Fluid and shifted to just their HG DOT 3?
    When did that start?
    Anyone have the part # for the HG Heavy Duty Dot 3 and the regular HG DOT 3? Seems to be the same part # but without the leading 0 (HD had the leading 0; regular sans 0).
    Thanks.
    Platinum Member mreggball's Avatar
    Jan 2015
    Yardley, PA
    1,304
    Unfortunately, I can't answer any of your questions, but I wanted to give you props for asking the most questions ever in a single post.
    2012 Civic Si sedan / Dyno Blue
    POP CREW MEMBER #615
    Retired:
    2014 Civic Si sedan / MSM
    2012 Civic Si sedan / Sunburst Orange
    2007 Civic Si sedan / Silver
    Oct 2016
    8
    Anyone?
  5. #4
    Ez1
    Ez1 is offline
    Sep 2013
    Diggin' in your fridge
    342
    0w20
    0w20
    Moly comes from the assembly lube used while building the engines, it's not anything extra or special in the oil itself. (Teeps posted about this in another thread long ago)
    I'd think you can find DOT3 just about anywhere. Seems like DOT3 is DOT3:
    https://en.wikipedia.org/wiki/Brake_fluid
  6. #5
    Oct 2016
    8
    Thanks.
    Was asking if the oil is conventional (with some moly for break-in - read this somewhere), syn blend (with the moly), or full syn ... during engine assy ... at factory ... for the '12 and '15 Civics.
    Also, what is definitive OCI for the factory oil? For HG syn blend? For HG full syn?
    Thanks again.
    Still also interested in Honda's changeover from Heavy Duty Dot 3 to their regular DOT 3.
  7. #6
    Ez1
    Ez1 is offline
    Sep 2013
    342
    Quote Originally Posted by Car guy View Post
    Thanks.
    ALL 0w20 is classed as either semi or full synthetic.
    Which type the factory installs, I don't know nor do I really need to know (nor care).
    Search the forum for 'break in oil' and maybe 'moly', read everything you can find written by Teeps. Here's one I found right away:
    http://www.9thgencivic.com/forum/9th-gen-civic-general-chat/191657-factory-oil-consumption.html#post3221233
    Per your owners manual:
    Change oil when the Maintenance Minder turns on the wrench light and 15% notification....... or one year, whichever comes first.
    The Maintenance Minder system operates based on a model, it has no way to directly monitor the true condition of your oil or any other fluid. It cannot monitor the level of the oil either.
    The model relies on the correct products being used, "typical" driving conditions, and the driver regularly checking and correcting the fluid levels.
    If one were to dump in the cheapest, most incorrect discount oil found at the Quicky Mart (for a 1928 Ford Model A?), the Maintenance Minder has no way of knowing that.
    HTH
  8. #7
    Oct 2016
    8
    Thanks for that good link!
    But, WHY does the OM (for both '12 and '15 Civic) state (exactly): "You may also use synthetic motor oil if it is lab eled with the API Certification Seal and is of the specified viscosity grade"?
    Also ... went into 2 different Honda dealerships. Provided VIN for the '15 Civic 1.8L and at other place provided VIN for the '12 Civic 1.8L. (Have never provided a VIN for a qt of oil before, but did so on purpose.) One place said - for the '15 Civic - to use HG Full Syn oil and they provided those qts ... and the other place - for the '12 Civic - said to use HG Syn Blend oil and they provided those qts.
    Part #s were 08798-9037 and 9036, respectively.
    But, both OM's have same oil 0W-20 information and same above statement.
    What gives?
    And, what is the oil change interval for Syn Blend ... and what is the interval for Full Syn?
    Thanks.
  9. #8
    Platinum Member Roadcourse's Avatar
    Dixie
    5,803
    Holy shit, another oil thread.......
    MeeSh likes this.
    Only the knife knows what goes on in the heart of the pumpkin......unknown
    Actively respect those that either died or endured misery....so you could be free.
    Drain the swamp. Force term limits.
    "The greatest trick the devil ever pulled was to make people believe he doesn't exist".......a movie.
  10. #9
    Oct 2016
    8
    <Only the knife knows what goes on in the heart of the pumpkin......unknown>
    They now know defensive chemicals get released, immediately.
    Same thing happens removing a fruit or vegetable or flower or leaf or blade of a grass.
  11. #10
    Ez1
    Ez1 is offline
    Sep 2013
    342
    And that API grade is.....?
    What gives?
    Your choice. Either flavor 0w20 oil can be used in either year.
    The parts people only sell parts. They don't always know nor care anything about the cars. I'm real sure they cannot look up oil using a VIN. The Honda electronic parts catalog does not have a listing for engine oil.
    I'd walk to the shelf and grab whatever oil bottles and ask which you'd prefer.
    If I were paid on commission selling parts, I'd push the most expensive option (or highest % profit choice) at you and tell you you MUST use it. (A quart of Hondas full syn is more than a dollar higher than the blend according to the parts catalog I just looked at)
    My store also keeps some flavors of Mobil1 on the shelf.
    Most dealerships probably have 3 choices for Hondas spec 0w20 oil:
    Bottled: either semi synthetic or full (ultimate) synthetic
    or bulk oil, which in the US is now full synthetic (if the dealer is obtaining bulk oil through Hondas recommended distributors).
    (That was just from memory. If you want some copy and paste from a real owners manual, I can probably come up with that...but I'm lazy.)
  1. Factory Oil Consumption ...
    By SI4ME in forum 9th Gen Civic General Chat
    Last Post: 08-21-2016, 03:15 PM
  2. Engine oil spraying all over engine bay
    By Erkon in forum Drivetrain Problems
    Last Post: 11-06-2015, 02:56 PM
  3. SI Factory oil consumption
    By Allmotor in forum Mechanical Problems & Technical Chat
    Last Post: 10-24-2014, 11:11 PM
  4. Si Oil Report on Factory Fill
    By rocko62580 in forum General Maintenance
    Last Post: 08-12-2013, 01:42 PM
