excessive heat
Results 1 to 10 of 29
Thread: excessive heat
    Junior Member
    Aug 2011
    3
    excessive heat
    I purchased a 2012 civic a little over a month ago and noticed excessive heat coming from all of the vents. The temp is turned all the way to cold and heat still comes from the vents, even with the fan turned off. Has anyone experienced this issue???
    Member
    Aug 2011
    Chicago
    70
    Does this only happen while you are driving? Also when your car is NOT recirculating air? If so even if the fan is off the intake is still open so you can still get air through the vents which passes by the engine picking up the heat while passing by. This is common in many cars I've noticed.
    Senior Member Anthony A's Avatar
    Jul 2011
    Southern California
    107
    Ya ive noticed it, it kinda gets annoying sometimes, i just tilt the vents up out of my direction and the problem gets solved
    - Black 2012 Honda Civic Lx
    - R18 Crew member #814
    Big Pimping!!! stringfellowhawke's Avatar
    Tampa, FL
    896
    Does hot air come out even with the recirculating vent on? I know if mines off I get a lot of heat, but if its on its very minimal if any.
    Member
    76
    Yep, same here, just tilt the vents up out of my direction. I will appreciate the free heat in the winter though
    2012 Civic EX Coupe, Dyno Blue Hidden Content
    Junior Member
    Aug 2011
    3
    It happens mainly when recirculation is off, less when it's on. It's definitely noticeable and that never happened with my 2001 civic I just sold. Seem a little odd to me. In addition, the fan doesn't even have to be on for the heat to be noticeable.
    I have not needed to be in for an oil change yet, but since it's so annoying, I'm going to have it checked out. They'll probably just laugh, but it seems like a defect to me.
    Tampa, FL
    896
    If the recirculating vent is off then its more then normal. My Mazda 3 was the same way. With the vent off you're pretty much pulling in heat from the engine. Now when its on you really shouldnt have much heat or air coming in at all. Just the inside air thats being circulated which may be a little warm if the ac isnt on, but defiantly shouldnt be excessive heat if the recirculating is on.
    2012 Honda Civic LX
    Dyno Blue Pearl
    Big Timer!!! Dieselnomore's Avatar
    Aug 2011
    Central Virginia
    189
    Quote Originally Posted by mstan View Post
    Keep in mind it was summertime. Some manufacturers incorporated insulated duct work to avoid condensation and heat transfer. The new cars with cabin mounted computers, and especially with displays and high watt stereo systems will generate heat. When the A/C is OFF and the vents are open the cabin will receive outside air temps plus any additional heat induced by roadway heat and internal computers.
    However, I do not know if the heater control restricts heater coil water or only regulates a damper. When a system incorporates a control "valve" all heating water "should" stop flowing and the temp of the water will eventually be neutral with the cabin, but when a duct damper is incorporated (and the heater core is located within the cabin radiating heat) you have a internal cabin vessel that is typically 195*; or whatever your operating temperature is.
    Junior Member
    Oct 2011
    excessive heat inside passenger cabin
    Glad I found this forum. My 2012 Civic LX is only 2 months old and I noticed that my car's cabin also gets very warm even when the temp is cool out at 68 degrees! It's blowing hot air with the temp set at the coldest, fan off, recirculation on or off. The vents themselves are warm to the touch. I've taken my car to the dealer 2x and at first they told me it's normal to have warm air coming out of the vents especially if I let the fresh air in (the air temp, btw, was 75 degrees when I noticed it the 1st time). Also, the circulation is not good with newer cars. The only remedy I was given was to always have the a/c on.
    Two days ago I went back, it was 68 degrees out, i was wearing shorts and a t-shirt with atleast 1 window down and I was still warm. I didn't even intend on going to Honda that day but I went anyway b/c I think it's unacceptable. I don't think it's normal that I need to turn my A/C on in the fall when the temp is cooler.
    So, they used a thermometer and found that the air coming out of the vents is 98 degrees. WHAT???? They told me they tested another car and they're only a few degrees cooler than mine. The manager told me that it seems the 2012 Civics don't have a water cooling system - this regulates the heating/cooling of the air that goes inside that car-- as it's not mentioned in the manual.
    I just read an article at Heater core - Wikipedia, the free encyclopedia. It says that engines that do not have a water cooling system can not use a heater core; one alternative is to guide air around the (very hot) engine exhaust manifold and then in to the vehicle's interior. Temperature control is achieved by mixing with unheated outside air. Depending on the design, this can cause a safety issue where a leak in the exhaust system will begin to fill the passenger cabin with deadly fumes.
    I don't think I can live with this problem as it could be dangerous. If Honda can't fix it, I intend on getting my money back! Maybe we all should file a complaint to Honda USA. I've never had this problem with any of my cars, even my 96 Honda accord.
    Aug 2011
    Central Virginia
    189
    Quote Originally Posted by vegasskibunny View Post
    ...."The manager told me that it seems the 2012 Civics don't have a water cooling system - this regulates the heating/cooling of the air that goes inside that car-- as it's not mentioned in the manual.....
    I just looked at my car and I have what appear to be the two hoses (supply and return) hot water system into my cabin. Now the mixing system may indeed be air as apposed to a hot water valve. I think you got some BS there. (Edit) Either one can fail or not shut off properly and cause your problem. And, I've heard that some car manufacturers who ship to the warm southern states do not include a heater core as standard equipment; but I have not read nor actually seen this.
  1. DIY S2CarbonWorks R18 Stainless Heat Shield
    By creation in forum Performance
    Last Post: 03-14-2013, 09:57 PM
  2. Excessive front break pad dust?
    By SLL in forum Suspension & Brakes
    Last Post: 11-09-2012, 10:54 PM
