Manual Driving Question
Results 1 to 10 of 27
Like Tree10Likes
Thread: Manual Driving Question
    Nooblets Lil White's Avatar
    Nov 2014
    Behind you
    45
    This is my first manual car and I pretty much learned driving from it. Trial and error has taught me many things >:| One question I have is if I am in traffic can I keep my foot down on the clutch and stay in first gear for long periods of time without it causing any problems? I wont be using any gas so i wont be riding the clutch or can you still ride the clutch without hitting the gas? I like to put my chair all the way back since traffic can be so bad and I cant really reach the gear if I am laying down lols.
    Black Honda Civic 2013
    Skunk2 MegaPower RR Exhaust
    Skunk2 Alpha Series Header
    K&N Intake
    P2R Throttle Body Spacer
    Hondata FlashPro
    VitViper Tune
    Hasport 70a RMM
    Acuity's Short Shifter(Handles like a dream)
    80k miles and counting!
    Top Dawg!! SYMAWD's Avatar
    New Jersey
    1,025
    It will put additional wear on the throw out bearing, but not the clutch.
    Civi9 likes this.
    May 2015
    22
    Not a good practice in general, as it does wear throwout bearing as SYMAWD mentioned, but amount of wear isn't major, if you don't do it a lot. I would just let it coast in first gear or even put in neutral to coast if necessary before I would do what you're doing.
    Platinum Member J.Dre's Avatar
    Mar 2012
    USA
    1,640
    Never sit for extended periods in first gear while holding the clutch in. That's a horrible habit. Slowly moving bumper-to-bumper traffic is only when this is acceptable. Imagine if you accidentally let off the clutch and bumped into the car in front of you... That wouldn't be good. Why would you want to hold the clutch, anyway? It can put strain on your leg and cause cramping.
    Just put the car in neutral if you're going less than 10 MPH and coming to a stop. Get used to using the brakes at that point. First gear should only be used in slow, bumper-to-bumper traffic or to take off.
    391
    Quote Originally Posted by J.Dre View Post
    LOL what? The car would just stall out. I don't think it is possible to "accidentally" take your foot off the brake and hold the clutch at the engagement point so that you would roll into the car in front of you. Come on. I am with you in that you should just put in in neutral and rest your foot on the dummy pedal just because that is the easiest thing to do physically.
    Mar 2012
    USA
    1,640
    Quote Originally Posted by HFP14 View Post
    Hey, I've seen it happen. People panic and make mistakes. Sometimes you can roll backward and hit someone as well.
    Just simplify things and use the brake.
    The way that I was taught... If you are going to be stopped for more than 5-10 seconds, put it in neutral and put on the handbrake. If you are stopped at lights and are the 3rd car back, put it in neutral and put on the handbrake. Otherwise, leave it in gear and leave your left foot firmly planted on the ground.
    Additionally, if you are stuck in traffic try to crawl along at low speed without stopping - it'll save you some left-leg-exhaustion
    Also - you don't need to hold it at the engagement point - I've jumped off the clutch before by accident and the car has gone forward 3-4 feet, sometimes that's just enough to cause a problem.
    391
    BS. The thing you are not understanding is his right foot IS ON THE BRAKE! He isn't going to roll anywhere just because he likes to leave the clutch depressed(which has the same effect as neutral anyway). Even if he "accidentally" held the clutch at the engagement point(impossible imo) he still isn't going anywhere because his right foot is on the brake. I can't comprehend how you even think that up.
    391
    Quote Originally Posted by rushlink View Post
    Why would you put the handbrake on stopped at a light? Seems like a useless extra step. Put it in neutral, rest your left foot on the dummy pedal and right foot on the brake.
    Nooblets joey_garbage's Avatar
    May 2015
    Your Rearview
    66
    With bumper to bumper traffic you have to get to the habit of the "half shift" 1st to neutral. Also called the "slap shift" because you slap the shift back into neutral because traffic is so f'ing slow! Just be careful if you have a heavy knob and it flys into 2nd...or even worse 4th!!
    You want to grow habits that make driving more comfortable...sounds like you are probably driving tense which is usual since you are a new driver. Just think of ways that you would be more confortable. Starting off in bumper to bumper traffic then half shifting into neutral, letting your foot off the clutch, and coasting sounds a heck of alot more comfortable than holding the shift in first and pressing the clutch down. Not to mention less wear on the car. :-)
    Heck in bumper to bumper traffic on a downslope I dont think I even use the tranny to move...brake and roll lol
