Grinding after full race install
Results 1 to 7 of 7
Thread: Grinding after full race install
    Sep 2018
    Ok so over the weekend I installed both the full race downpipe and exhaust. There’s a bit of rattling but I have parts coming in to fix that. The main issue I’m having is that every once in a while during acceleration, I can feel and hear a slight hissing and grinding coming from under my shifter area. I don’t see any clearance issues. Does anyone know why this might be happening?? Do I need to tighten down the bolts more??
    Quick reply to this message Reply
    Sep 2018
    Oh and I have a 15 si
    923
    Do you have an aftermarket rear engine mount? If not the downpipe could be hitting the subframe when the engine rocks
    Otherwise it could just be normal downpipe noise, is yours catted or not?
    Baned
    Arizona
    8,521
    Or something could be rubbing on the strut tower bar if you have one of those. The noise is coming from under your car, like under where the gear shifter is?
    Sep 2018
    Yes I have the hasport 62A or 70a I can’t remember which one but it is upgraded. And maybe. It like a faint clinging sound and sometimes sounds like it’s grinding. My downpipe is catted and exhaust and downpipe are both by full race.
    Sep 2018
    Quote Originally Posted by DWils View Post
    I checked all clearances but the height does change a bit when I lift it vs when the struts settle so I can’t exactly tell. And I think I’m hearing it right under where my gear shifter is but it could just be vibrations that traveled to that point I honestly have no idea.
    Sep 2018
    Ok so I’m noticing that the rear most exhaust mount keeps sliding out of the hook. Could that just be what’s going on? I got a polyurethane 90 degree mount on the exhaust but is that usually enough?
  1. Extreme rasp after vit tune with full race exhaust setup
    By RyanFG4 in forum Exhausts and Downpipes
    Last Post: 03-29-2017, 03:30 PM
  2. Rattle noise after full race DP Install
    By Mordalo55 in forum Exhausts and Downpipes
    Last Post: 05-20-2014, 08:12 PM
