Looking into 9th gen Civic si - Page 2
Results 11 to 12 of 12
Thread: Looking into 9th gen Civic si
    Dec 2018
    Washington, DC
    17
    Like what others have said, $18.5 is steep for a '15 Si with that many miles, even if one owner and well kept. What I'd also say in response to what some here have said is that the '14 and '15 Si have retuned exhaust systems, adding a bump in HP and torque. Not much, like ~4hp and torque, but still something to note if you're on the market for a 9th gen Si and want the most bang for your buck. To me, this is something to take note of.
    A common issue these cars seem to have is a type of grinding/screeching noise when engaging the clutch in first gear sometimes. What I'd recommend if you're serious is taking the car for a long test drive, and engaging first gear from a stop while on an uphill and doing this multiple times to be sure. While I've heard that the noise is not indicative of a serious issue, it's still really annoying, has turned heads, and is generally not a noise that a low mileage car should be making.
    Aug 2017
    I got a 2012 Si Coupe for $14,500 in 7/17 with 38K miles and in excellent condition. That was taxes, dealer doc fee, and everything else. Based on what I've read, the early 2012s had an oil usage issue that was eventually corrected. So if you go with that year, look up the dealer service bulletin that lists the range of serial numbers for cars that had the problem. The 2012 also does not have the soft touch dash or as much sound deadening material as the 2013 and later models. This does save a little weight from what I read, but it is a bit noisier ride when the windows are rolled up.
    The car is a blast to drive and I have not had any major problems at 65K miles. It will probably need a clutch in another year and some new tires soon, but that is to be expected. I'd like to get a tune on the car, but the money has to be spent elsewhere right now. The 9th gen also has the exhaust manifold cast into the head, so keep that in mind if you're thinking about modding it. Forced induction will extract a good deal more power, but the kits are not cheap and then you may want to install beefier rods as well. Even if you do the labor yourself, you will probably spend several thousand on parts alone.
    Good luck with it!
  1. Is 9th Gen Civic forum turning into just Civic forum?
    By thaicivic in forum 9thGenCivic.com Site Help
    Last Post: 02-23-2013, 09:14 PM
  2. Rbc Cai Soultion 8th Gen AEM Cai into 9th Gen Si
    By dagocrazy in forum Intakes and TB Spacers
    Last Post: 01-21-2013, 08:54 PM
