Having trouble with high beam !
Thread: Having trouble with high beam !
    Hey guys so I installed some led for the drls everything works except that when the drls are on I can’t use my high beams. When I have the headlights on I can use the high beam if anyone knows how I can fix that would really appreciate that 🙏
    2,666
    I suggest you contact the people that made/sold the led kit.
    What model, year and trim level is your car?
    Any other aftermarket mods?
    See link in my sig line below.
    821
    You can't use an led in the high beam/DRL. Because the DRL uses a resistor to run the high beam at half power. And led can't do this.
    Instead your highbeams are at full power all the time and could be blinding people. You really should remove the led from the high beam.
    Honestly an led shouldn't be used in a non projector housing at all. High beam or low beam
    Super Mod's Pet baby_blue_6_4's Avatar
    May 2015
    RVA
    658
    I'm running LED in my DRL and they work just as halogen ones do. You just need to get the right ones (morimoto 2.0 led) and get an anti flicker relay so they work as they are stock. Much cleaner look and I never use them as high beams anyway since my lows are so bright to begin with (UAE HID hybrid projectors)
  1. HID kits High Beam Low Beam and Fog lights
    By Cagatay in forum Lighting, H.I.D.'s, & Neon
    Last Post: 10-17-2014, 11:26 AM
  2. Replies: 6
    Last Post: 05-30-2013, 08:04 PM
  3. Replies: 32
    Last Post: 08-23-2012, 07:36 AM
