A Build of Simplicity - Page 14
Page 14 of 16 FirstFirst ... 41213141516 LastLast
Results 131 to 140 of 155
Like Tree28Likes
Thread: A Build of Simplicity
  1. #131
    668
    Curious to see the numbers after the rbc swap and tune.
    Likewise and im wondering if doing a port and polish job with matching to the zdx throttle body is worth it compared to running our stock TB. I used to follow iketh since hes in orlando which is 1.5 hours away and his friend was running a pp rbc with zdx tb and was making 230whp and 186wtq no sae correction with the temp at 88 degrees and 88% humidity but hes also got pullies. His IAT were staying at mid to low 90s.
    Follw me on IG: fl_fg4
    205 whp
    174 wtq
  3. #132
    One Bad Mama Jama!!! TenZen's Avatar
    Apr 2016
    376
    Quote Originally Posted by 12FG4Rallye View Post
    God damn I want a HFP kit. But so pricey.
    2015 Rallye Red Si Coupe
    Acuity Curl CAI, Hasport Torque Mount & Rear Motor Mount, Acuity Shift Linkage & Shifter Base Bushings, Acuity ESCO Shift Knob, BFGoodrich g-Force COMP-2 A/S, FKX RSB/LTB, SiriMoto FSB/RLTB, Full Race Cat-Back, RV6 Catted DP
  4. #133
    1,141
    Those were the numbers i've been seeing as well. Which is a solid 25hp and like 10 tq over the factory manifold. If that holds true then I'll def be doing the rbc.
  6. #134
    668
    Quote Originally Posted by TenZen View Post
    It is, i saved for awhile and luckily at the dealership i work at i was able to get a discount so that definitely helped.
    205 whp
    174 wtq
  7. #135
    668
    Will definitely be posting up numbers and graph when its done so we can see but those pullies are probably adding another 4-5whp if they do what they say. If i can get 220whp with the stock tb and non p&p manifold id be happy lol
    205 whp
    174 wtq
  8. #136
    668
    Kit came in 😃
    Attached Thumbnails Attached Thumbnails A Build of Simplicity-4075be72-5f97-4ad5-a51c-1180d940ce30_1560875672679.jpg
    205 whp
    174 wtq
  9. #137
    Apr 2016
    376
    Hey, it's me, your best friend.
  10. #138
    668
    Ordered my sirimoto ev14 550cc injectors for the RBC swap 😃 only a couple more things
    205 whp
    174 wtq
  11. #139
    1,141
    What else you need?
  12. #140
    668
    What else you need?
    The prl throttle body adapter to run my stock throttle body and then the acuity intake coupler for the rbc and stock TB.
    205 whp
    174 wtq
  1. Minimalist's Build XP: 2015 ASM Sedan SI Build
    By xeroxp in forum Build Section
    Last Post: 02-17-2016, 05:37 PM
  2. My fg4 build so far!
    By The Pacman in forum Build Section
    Last Post: 05-20-2015, 11:37 PM
  3. Replies: 8
    Last Post: 05-20-2015, 02:42 PM
  4. Feral's TW SI Build :3
    By Feral in forum Build Section
    Last Post: 03-30-2014, 05:28 PM
