14' Si Coupe - Orange Fire Pearl - Turbo Awakens
Results 1 to 10 of 24
Like Tree8Likes
Thread: 14' Si Coupe - Orange Fire Pearl - Turbo Awakens
    Big Timer!!! Chambers805's Avatar
    296
    Hello,
    Thought I would share the light on some of the mods I've been installing as well as my current install of a Makspeed Turbo kit with Comp 6062 Ball Bearing Turbo. Also a beta of kseriespros.com soon to come ethanol content sensor kit for Hondata.
    Here's what I first installed.
    D2 Lowering Springs
    Truhart Shocks
    Skunk2 DP
    SPC Camber Arms
    Modded Stock CAI
    Hondata Flashpro and Tuned with VitViper - Best upgrade
    Stoptech Slotted/Drilled Rotors
    Hawk HP Plus Pads
    Stoptech Stainless Steal Brake Lines
    Made just under 200whp and drove great, perfect setup for daily. The brake setup was a little extreme for daily as the pads can be really noisy and they get dirty quickly but damn could they bite. I then wanted something a bit stiffer as I am a track enthusiast and needed my car to rotate better.
    Here's what I've added/replaced and have been running for the past year.
    Action Stage 1 - Clutch w/Lightweight flywheel
    Godspeed 2-Way Monomax - 12KG Front 14KG Rear (Don't recommend for daily, but I do it anyways)
    Siromoto Middle and Front Subframe Braces
    Sirimoto Trunk Brace
    Progress 24mm Rear Sway Bar - 2nd best upgrade
    FKX Racing Rear Subframe Brace
    Tanabe Axle Back
    Konig Hypergram 17x9 +25 - 16lbs and Flow Formed Cast like Enkei
    Federal 595rr - 255/40-17
    Acuity Bushings & Boot Collar Kit
    All Amsoil Fluids
    -Engine 5w-30 w/Filter
    -Transmission MTF
    -Brakes Dominator
    -Wetter Coolant
    Now comes the big install which I've just about finished up. Here
    Makspeed Turbo Kit w/Black Powder Coated Piping & Upgraded Comp 6062 Ball Bearing Turbo
    Gear-X 1st-4th W/ RSX Type-S 4.3 Final Drive
    Action Stage 3 - Clutch w/Lightweight flywheel
    Beta of Kseriespros.com Ethanol Content Sensor Kit
    I can't get the images to load with bb code so i'll post links, also you can follow me on Instagram @jchapman805
    Images
    https://drive.google.com/file/d/13mU...ew?usp=sharing
    https://drive.google.com/file/d/1LCx...ew?usp=sharing
    https://drive.google.com/file/d/16I3...ew?usp=sharing
    https://drive.google.com/file/d/1R47...ew?usp=sharing
    https://drive.google.com/file/d/1_B0...ew?usp=sharing
    https://drive.google.com/file/d/1Y9J...ew?usp=sharing
    https://drive.google.com/file/d/1gK5...ew?usp=sharing
    https://drive.google.com/file/d/1n2t...ew?usp=sharing
    https://drive.google.com/file/d/15Zh...ew?usp=sharing
    https://drive.google.com/file/d/1HPQ...ew?usp=sharing
    https://drive.google.com/file/d/1J7G...ew?usp=sharing
    https://drive.google.com/file/d/1bjj...ew?usp=sharing
    https://drive.google.com/file/d/1GVY...ew?usp=sharing
    https://drive.google.com/file/d/1KmG...ew?usp=sharing
    https://drive.google.com/file/d/1wSu...ew?usp=sharing
    https://drive.google.com/file/d/12sC...ew?usp=sharing
    https://drive.google.com/file/d/1t-K...ew?usp=sharing
    https://drive.google.com/file/d/1v1O...ew?usp=sharing
    https://drive.google.com/file/d/1BUA...ew?usp=sharing
    https://drive.google.com/file/d/19MV...ew?usp=sharing
    https://drive.google.com/file/d/1vT5...ew?usp=sharing
    Video's
    https://drive.google.com/file/d/1t86...ew?usp=sharing
    https://drive.google.com/file/d/1jn4...ew?usp=sharing
    K24Z7 - Crew Member #373
    14' Honda Civic Si Coupe
    GodSpeed 2-Way MonoMax Coilovers
    MakspeedTurbo Kit - Comp 6062BB
    Vit-Viper Tuned
    Action Clutch -
    Stage 3
    Hawk Performance Brakes
    Progress Sway Bar
    GearX - 1-4th w/RSX Final Drive
    1,048
    Those red wheels are pretty awesome.
    Chambers805 likes this.
    296
    Thanks! They are really inexpensive, I paid a little over 500$ for the set. Konig Hypergrams 17/9 +22, I think I may order the Dekagrams next. They're Flowformed just like enkei so they're pretty strong and light for a non forged wheel.
    Vit-Viper Tuned
    Action Clutch -
    Stage 3
    Progress Sway Bar
    1,048
    Yea, I was gonna go with some konigs, but my distributor for them doesn't take credit cards, had to go with the motegi's same flow form type deal
    8
    Is the modified stock CAI mostly for sound?
    296
    Quote Originally Posted by rsr552 View Post
    It actually improved the air intake, not just for sound. After the tune It picked up just as much as a Short ram intake without as much heat soak imo. Short rams are useless though, if you do happen to go CAI I would stick with Acuity or PRL.
    Vit-Viper Tuned
    Action Clutch -
    Stage 3
    Progress Sway Bar
    Aug 2017
    224
    Quote Originally Posted by Chambers805 View Post
    Did you have to do any fender rolling? Or even pulling?
    2014 Civic Si Coupe
    LED Headlight and Foglight Bulbs
    Acuity - Short Shifter, CAI, Coolant Hoses, Shift Bushings
    Mishimoto 155 °F thermostat
    RBC Intake Manifold (Cut, ported and polished), PRL Adapter
    RDX Injectors
    Fullrace 3” - Catted Downpipe
    Invidia Q300
    Innovative - 75a RMM
    BC Racing DR Coilovers
    Swift Springs
    Skunk2 Camber Arms
    296
    Quote Originally Posted by Daver View Post
    There was rub, I pulled a little bit but I didn't mind it takes hoursssss pulling the fenders. My next move is to cut the back half of the front fenders off and pull them out way more. About to pick up some RPF01's in 18x11 +8 fronts and 18x9.5 rears. Been looking to also do fender flares, been eyeballing some super20 fender flares and slicing it up to fit the wheels wide body.
    Vit-Viper Tuned
    Action Clutch -
    Stage 3
    Progress Sway Bar
    296
    It's been a minute since I updated this thread so I'll just post some images and add to the list. I've so far been compiling a bunch of car parts for another big install coming soon.
    Part's ready for next install:
    RBC Manifold w/Hondata Gasket
    Tractuff K24z7 Coolant Bypass
    Manley H-Beam Rods
    Wiseco 87mm Piston's
    Supertech Valve Spring & Retainers Kit
    PRL Coolant Hoses for RBC manifold
    ARP Head Studs
    K24z3 Long Block - Sending to Cylinder Support Systems for 800WHP Rating w/O Rings
    10Ft. -10AN Vibrant Hoses w/Fittings for Oil Cooler
    Torque Plate
    Things I still need:
    DW 300C Fuel Pump
    2000CC+ Fuel Injectors
    Radium Fuel Rail w/Fuel Pressure Regulator
    Oil Cooler Radiator
    Koyorad radiator
    and lets not forget more $$
    14' Si Coupe - Orange Fire Pearl - Turbo Awakens-54730429_1160602424100799_926122612625506304_o.jpg
    Vit-Viper Tuned
    Action Clutch -
    Stage 3
    Progress Sway Bar
    Big Timer!!! kevvo21's Avatar
    Sep 2016
    Toronto, Canada
    218
    what a crazy build! nice
    2014 DBP Si Sedan
    "Drop a gear & disappear"
  1. Civic Sedan Si 2015 Orange Fire Pearl
    By kenyel in forum New Member Introductions
    Last Post: 01-06-2016, 09:24 AM
  2. 2014 Orange Fire Pearl SI sedan
    By j8racing in forum New Member Introductions
    Last Post: 07-01-2015, 08:51 AM
  3. New 2015 Orange Fire Pearl Civic Si sedan....
    By Wesker in forum New Member Introductions
    Last Post: 03-18-2015, 10:07 AM
  4. Honda Head Got a 14 Si - Orange Fire Pearl
    By dgaplin in forum New Member Introductions
    Last Post: 07-10-2014, 10:18 PM
