Will Honda work on improving their transmission?
Results 1 to 10 of 29
Thread: Will Honda work on improving their transmission?
    Junior Member
    Nov 2010
    11
    Honda's 8th generation Civic Si coupe had a few too many problems with the 6MT transmission such as resistance going into 2nd and/or 3rd gear, grinding, transmission kicking out/popping out into neutral from 3rd, and some not so common problems. Also other models from Honda have transmission problems.
    Do you think the 9th generation civic will have similar problems, or if Honda will even work on improving their bad transmissions?
    Member
    Nov 2010
    83
    Its hard to say if the 9th gen will have the same problems but I am sure Honda will be working on fixing these issues to help keep the customer base they have. Honda is known to be one of the best in the market, keeping that rep is priority to them.
    Senior Member
    Nov 2010
    266
    if this helps, for the 2012 Honda Civic they will have 3 different transmissions available:
    - CVT ( continuously variable transmission )
    - Automatic transmission
    - 6 speed manual transmission
    Junior Member
    Dec 2010
    Long Island, NY
    21
    civic with a cvt...thats pretty interesting!
    sew
    sew is offline
    Senior Member
    Feb 2011
    Arkansas - very rural
    214
    I have a 2008 4dr Si and have resistance going into 3rd gear unless the car has been driven a # of miles, ie thoroughly warmed-up(like 10+ miles). The car has never been speed shifted or driven hard, by most people's standards. It has 29,000 miles, is not in the re-call range(serial # wise) for this problem. My salesman says it does seem to have a problem but the mechanics at the dealership say it isn't bad enough to do anything: that it's relatively normal. I have gotten some Amsoil Synthetic Trans Fluid but haven't put it in yet. Probably will tomorrow. This reluctance to smoothly engage 3rd gear has been my only complaint with the car, except wishing it had the 240 hp k24 out of the later S2000s. Ideas on this trans problem???
    Feb 2011
    19
    Quote Originally Posted by Hondapwr View Post
    How about the 5 speed manual, are they dropping it?
    Lek
    Lek is offline
    Member
    Dec 2010
    54
    90% made in China and Thailand, but assembled in the US.
    Senior Member Talon's Avatar
    Jan 2011
    So.Cal
    2,502
    sounds like most the complaints are the same and all about the manual tranny.....is there any known inssues with the AUTO?
    Hidden Content Go hard or go home, but never go home hardHidden Content
    Hidden Content | Hidden Content | Hidden Content
    Senior Member dashline79's Avatar
    Feb 2011
    Hi-Life in the Aloha State
    794
    Check the press release
    All-New 2012 Honda Civic Emphasizes Style, Fuel Economy and Performance - Honda.com
    In the Si section they do emphasize a "new 6-speed manual transmission."
    So one would suspect that Honda is trying to address this long run issue.
    sew
    sew is offline
    Senior Member
    Feb 2011
    214
    As posted repeatedly by others on 8th Gen Civic, the Amsoil manual transmission fluid helped my transmission significantly. I think this is what the transmission should have come with originally.
  1. Tech trippin' ?? Gear lubes: Which is what and what goes where??
    By davey101 in forum General Maintenance
    Last Post: 02-19-2013, 03:41 PM
  2. Continuously Variable Transmission (CVT)
    By K>H>B>D in forum Drivetrain Problems
    Last Post: 08-17-2011, 10:14 AM
