Sputtering Misfiring At Very Light Throttle Need Help
Results 1 to 10 of 11
Thread: Sputtering Misfiring At Very Light Throttle Need Help
    Apr 2017
    32
    Whats going on guys, I very recently started experiencing some pops and sputters in my idle and while driving at very low throttle (MAP psi @ -17 or lower). Also, if i bring the rpms to about 2k from idle, it just non stop sputters and pops. No changes in my setup just kinda started happening out of nowhere. No CELs but i have misfire detection off due to flywheel so idk if i would be getting one. But anyways, car seems to run completely fine at higher throttle and under more load, havent pushed it much though since this started. Car is heavily modified , will list below.
    2013 Si
    -Tuned by VitViper
    -Ct Supercharger w/ 1000cc injectors
    -Full bolt on i/h/e catless
    -Clutch Flywheel (Misfire detection disabled)
    My first guesses were ignition coils, or possibly injector related but im not knowledgeable enough to really know what the deal is, so any advice would be greatly appreciated.
    On side note, i recently have been messing around with my secondary o2 sensor to try and pass emissions, and left the sensor unplugged. the sputtering (coincidentally i believe) started right after. the sensor is disabled in the tune so i dont think this would have any part in this but figured id mention it.
    Thanks!
    26,753
    I'm no expert, but if the problem began right after you did something, undo it, and see what happens.
    Teeps likes this.
    2,646
    scotty should this thread be moved to the forced induction section?
    Misinformation is far worse; than NO information...
    Apr 2017
    32
    Quote Originally Posted by scottyrocks View Post
    Scotty thanks for the response, I have seen you on these forums since i joined way back (2014 even thou it says 2017) glad to see a familiar name. But yeah im thinking you have a good point. I am getting a new sensor today will install and see if that fixes it. For some reason the original sensor wouldnt clip back in even thou it didnt look messed up. Hopefully its just this sensor will update when i install
    26,753
    I don't think this is a supercharger issue, per se, but rather an electronics issue. I could move it, but possibly into the ECU section.
    2,646
    My thought is the car is not stock. And, the supercharger changes everything on the intake side...
    I just think the OP will get better insight to the car's problem in the Forced Induction section.
    26,753
    Okay, let's see what happens. Then it will be moved as per the cause of the problem.
    Supporting Vendor procivic's Avatar
    May 2012
    Ventura, California
    615
    How long have you had the Injectors on this car for? It's possible they are a bit dirty/clogged. Considering they're 1000cc injectors, they can become very sensitive at low pulse widths such as the idle and light cruise situations you were describing.
    Apr 2017
    32
    Quote Originally Posted by procivic View Post
    The injectors are from 2015/2016, should i throw some injector cleaner into my fuel tank to clean?
    On a side note, i just swapped the secondary o2 sensor for a new one, problem is still happening. I will be swapping the primary tomorrow, i was cleaning my defouler with wd40 so incase some how it got hit with some and got messed up im going to swap.
    May 2012
    Ventura, California
    615
    Trying to clean them yourself with a cleaning solution might work, but nothing would compare to sending the injectors out to get flow tested and professionally cleaned.
  1. Need help civic misfiring
    By cukalevm in forum 9th Gen Civic General Chat
    Last Post: 03-24-2014, 04:07 AM
  2. Very cool, very useful, very inexpensive (if you already have a smart phone)
    By Victor.S in forum Electronics, Gizmos and Gadgets
    Last Post: 08-19-2012, 07:47 PM
  3. Replies: 3
    Last Post: 04-20-2012, 12:05 PM
