car clicks when turning ignition - Page 3
Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: car clicks when turning ignition
  1. #21
    Nooblets CNelms's Avatar
    Apr 2017
    Church Hill, TN
    33
    I'm crossing my fingers this is it. I hate to think about the money i can get into if it isn't
  3. #22
    Greenhorn StephenFB6's Avatar
    Before spending money on a starter, try a new starter relay, if it’s damaged in some way or has any extra resistance inside, it could cause an intermittent click if it’s not allowing full current to flow from the battery to the solenoid.
    From there, if your problem is not solved I’d suspect the contact plate in the starter solenoid , that completes the circuit to the starter motor may be corroded or loose, hence the repeated clicking but no cranking
  4. #23
    Apr 2017
    Church Hill, TN
    33
    I'll look at the relay. I tried getting the starter off and its an absolute pain to get those bolts out
  6. #24
    Apr 2017
    Church Hill, TN
    33
    Update #2: Issue is clutch switch
  7. #25
    1,048
    Quote Originally Posted by CNelms View Post
    Got it fixed?
  8. #26
    Apr 2017
    Church Hill, TN
    33
    Got it fixed?
    Got it fixed. Thanks everyone for the help!
  9. #27
    Greenhorn J9thGen's Avatar
    7
    Great job. But why would that cause the click sound?
  10. #28
    821
    Quote Originally Posted by J9thGen View Post
    Agreed, I didn't even think of the clutch switch because theres generally no sound when the ignition switch is disabled.
    Glad it is fixed though. A good reminder to start small and work up.
  11. #29
    Glad you got it fixed.probably clicked because there was some current going through the circuit just not enough to crank the motor at times
  1. car loses power when i press ignition, no power at all until i pull the battery termi
    By fuzzysig in forum Mechanical Problems & Technical Chat
    Last Post: 12-11-2018, 08:15 AM
  2. Weird clicking sound when turning ignition
    By CaptainJango in forum Mechanical Problems & Technical Chat
    Last Post: 06-27-2015, 07:11 PM
  3. No response from car when I switch ignition
    By DerekJA in forum Mechanical Problems & Technical Chat
    Last Post: 12-12-2013, 04:00 AM
  4. AEM FIC (Fuel ignition controller)
    By AllAboutAlloy in forum ECU Tuning
    Last Post: 08-23-2012, 11:48 AM
  5. MSD Ignition on Civic SI?
    By casualvic in forum Engine, Engine Swaps, Pulleys, Injectors
    Last Post: 03-03-2012, 07:28 AM
