B13 code from the Maintenance Minder
Results 1 to 5 of 5
  • 1 Post By Jamis
Thread: B13 code from the Maintenance Minder
    Platinum Member Jamis's Avatar
    NWOH
    1,808
    Black Betty just turned 54K miles and the MM popped a B13 code on the iMID. I know what the codes mean, but this is the first "3" that's been displayed. I've been waiting for the MM to call for a transmission fluid change, but does Honda mean a total flush, or just a drain and fill? If it's a D&F, how much fluid it needed? I do my own oil/filter changes, and will do the trans-axle also if it's just a D&F. I've done the D&F on all of my prior cars with no issues.
    2013 CBP EX-L sedan w/Navi.: K&N Drop In
    54,000 Mi.;Avg MPG:33 city;44 hiway;87 E10;ECON On
    79 mos. old, not a single problem, issue, or recall.
    2017 Milano Red Fit EX-L w/Navi. K&N Drop In
    17,000 M. Avg. MPG 35 City, 45 Hiway 87 E-10 ECON On
    I've gone out to find myself. If I return before I get back, have me wait for me.
    Old Age & Treachery Trumps Youth & Exuberance.
    855
    General consensus is that you never flush a transmission. Drain and fill only.
    2 quarts of Honda mtf. The service manual says that you must have the car level and fill it until fluid runs out.
    There are some good faq on this site or you can use this link
    2,686
    Quote Originally Posted by Jamis View Post
    Just drain and refill.
    Assuming your car has a "Honda standard" automatic transmission, (not CVT), use the proper fluid.
    855
    Whoops, that's what I get for assuming...looks like the OP has an ex which I assume is auto.
    NWOH
    1,808
    Thanks. It's a regular old 5 speed automatic. I think 3 quarts of Honda ATF DW1 will get me done. Just gotta check and see if my transmission funnel fits into the dipstick tube and that I have the proper sized crush washer.
    And here's the thread I originally started 5 years ago on this subject and forgot about. My bad.
    https://www.9thgencivic.com/forum/ge...id-change.html
    Teeps likes this.
