1st Gear Clutch Noise - Page 67
Page 67 of 69 FirstFirst ... 17576566676869 LastLast
Results 661 to 670 of 689
Like Tree115Likes
Thread: 1st Gear Clutch Noise
  1. #661
    Nov 2016
    29
    Quote Originally Posted by Fluxxed View Post
    God dammit. My car just started doing this too - right at 60,100~ miles. Perfect timing.
    Any idea what this is? I've read about 20 pages of this thread and there are so many conflicting answers I'm not sure what to believe or where to start.
    Is is the tensioner pulley? Is it something to do with the clutch springs as some have mentioned? Hot spots? I'm not super familiar with diagnosing car issues and don't know enough to get into it myself so any help would be very much appreciated.
    Only seems to happen sometimes in 1st (and occasionally, but more rarely in 2nd) as the clutch engages (as in, as I left my foot off the clutch).
    I'm still just as confused with all of these responses... Is it clutch springs? Tensioner pulley? A bad clutch?
    I'm past the warranty on mine now, so I don't know what to do - if it's worth bringing in and getting it looked at, and potentially fixed, or just dealing with it for now. (I don't want to ignore it and potentially ruin something in doing so, though)
    How have any of you without a warranty approached this issue? What did you do/what was the solution?
    2012 Honda Civic Si Coupe - Crystal Black Pearl.
    VitTune in progress!
  3. #662
    One Bad Mama Jama!!! puffaroach's Avatar
    Sep 2013
    Canada
    438
    So I took my car to the stealership and they gave me the regular robot response “We have never heard of this issue or this service bulletin. If we don’t find a issue then we have to charge you $150 for diagnosis time. You are past the 3 year warranty but because you purchased the extended it might be covered. We just have to wait for the warranty guy to review it”. I sure hope it’s covered as I don’t need a $1500 bill.
    Sent from my iPhone using Tapatalk
  4. #663
    Jun 2017
    7
    Also Have this issue on my 14 civic SI headed to the dealer soon.
  6. #664
    Mar 2018
    4
    Hey guys, I'm experience the same 1st gear clutch noise everyone is talking about in this thread. 2013 67k, pretty much out of warranty. I don't mind paying out of pocket, for repairs but I want to know if this issue will return if I replace it with the OEM parts.
    Were the parts at fault revised to fix these problems? Or should I just look at aftermarket?
  7. #665
    2,706
    Quote Originally Posted by FormerF20c View Post
    Probably.
    Last I heard before my internal source retired 2 years ago; NO.
    Sorry, no experience with after market clutch parts.
  8. #666
    Platinum Member MugenSi's Avatar
    Stockton
    1,892
    I remember reading heavily on this topic and users that got it replaced by the stealership ended up with the same issue. Supposedly the stealership says it does not afffect performance and will keep coming back no matter how many times you replace it with the stock clutch. You’ll have to go aftermarket.
    TW Si Sedan! Hidden Content
    4 doors 4 more whores
    K24Z7 Crew member #623
    Hidden Content Originally Posted by Stigmacher Hidden Content
    You must have a 2013 then?
    It's always 100 lbs heavier
  9. #667
    Big Timer!!! sekngen's Avatar
    Oct 2013
    120
    I was under the impression that the parts are revised versions of the original. These are the part numbers for everything that was installed on my car:
    94109-14000 90400 WASHER, DRAIN (14MM)
    94109-20000 90400 WASHER, DRAIN (20MM)
    22300-RX0-005 22300 DISK, PRESSURE
    22103-PNA-003 91430 BUSH (21X24X8)
    22200-RX0-005 22200 DISK, FRICTION
    22100-RX0-005 22100 FLYWHEEL
    22810-RPN-003 22863 BEARING
    90305-SD4-003 90200 NUT, SPINDLE (24MM)
    08798-9031 08201 FLUID, MT
    2013 Honda Civic Si Sedan Taffeta White
  10. #668
    Big Pimping!!! Lunch_Money's Avatar
    MD
    864
    Quote Originally Posted by MugenSi View Post
    I had mine replaced twice by the dealership. Noise eventually came back. It's gotten to the point where I can recreate the noise on demand.
    2013 PMM Si Sedan
  11. #669
    Big Timer!!! General_Lee_Si's Avatar
    Hazzard County
    202
    If it makes you all feel better...my 2015 Si Coupe has started to make the same noise at around 16k. I have 16600 miles on the odometer at the moment. The car will be 3 years old on 6/30.
    I have a hard time believing it could be the clutch...I barely drive the car and I definitely do not abuse it.
    2015 Alabaster Silver Metallic Civic Si Coupe w/Navi "Hella Stock and Hella CDM, Yo!!!"
    2014 Orange Fire Pearl Civic Si sedan (traded in for ^ )
    Current Mods: Driver Hidden Content Hidden Content
    9th Civic POP Crew member #73
    9th Civic LI Crew member #73
  12. #670
    Nooblets celi703's Avatar
    Oct 2014
    30
    I have a 14 Si Sedan with only 43,000 miles and had the noise since about 35k or so. Decided to have a local shop install the clutch and found the clutch springs to be the problem. One was very loose making the noise. New clutch kit and throwout bearing in the car and no more noise hopefully it never comes back.
    14' FB6 TW
    90' ST185 3E5
  1. Car won't go into 1st Gear 3rd Gear OR 5th
    By SRT Frank in forum Drivetrain Problems
    Last Post: 06-19-2013, 04:54 AM
  2. Rocking in 1st Gear
    By SnowShow in forum Drivetrain Problems
    Last Post: 05-29-2013, 08:31 PM
