unset readiness codes
Thread: unset readiness codes
    Jan 2017
    15
    Hello,I have a 2015 Honda Civic Si, I have reflashed back to stock tune to pass my states safety and emissions annual test; I have disabled the primary O2 sensor, given I have an aftermarket catted downpipe and cat back exhaust system (K Tuned). Since the reflash I have logged/driven several hundred miles, today (10-20-2018) it failed the state test due to it not being ready, to many unset readiness codes ( Catalyst, Fuel System and Evaporative System). Is this normal? How long and and could the primary O2 sensor being disabled cause this not readiness codes? Anything you can recommend b/c I am in a serious time crunch to complete this state inspection. Thank you
    George
    Aug 2018
    Boston, MA
    86
    Anytime you switch a tune, it’s like pulling the battery and all the sensors need some time to reset. You just need to drive around 100 miles before going to do emissions testing next time. All of the emission sensors should turn on by then.
    Sent from my iPhone using Tapatalk
    2015 FB6 DBP Si
    26,966
    He said he drove several hundred miles after the reflash.
    Apr 2017
    46
    Quote Originally Posted by GeoUCF14 View Post
    George
    I believe you are referring to the secondary o2 sensor as most tunes do not disable the primary , atleast that im aware of. Regardless, disabling the secondary o2 sensor will cause the Oxygen Sensor Monitoring monitor to not complete, AND that monitor is required for the Catalyst Monitoring check to ready up too. So you will have those 2 monitors not ready from having the secondary o2 sensor disabled (this is what happened to my car)
  1. Replies: 30
    Last Post: 09-20-2017, 06:18 AM
  2. Evap system pressure/ evap system readiness
    By 13Si-vtec in forum Mechanical Problems & Technical Chat
    Last Post: 09-21-2016, 06:37 AM
  3. Random Misfire Codes Bad Coil Codes Need Help !!!!
    By dyoo85 in forum Mechanical Problems & Technical Chat
    Last Post: 09-26-2015, 09:02 AM
  4. Inspection readiness failed
    By tyte07 in forum Mechanical Problems & Technical Chat
    Last Post: 09-05-2015, 06:53 AM
  5. Chassis Codes?
    By MDK20FG2 in forum General Maintenance
    Last Post: 02-14-2013, 10:37 PM
