I have been playing around in FP Manager since getting my flash pro a couple weeks ago. I recorded a couple 3rd gear WOT datalogs to play around with in FP Manager to try to familiarize myself with the software. Im running the reflash tune for now until I throw on a few more bolt-ons. Am probably planning on doing a dyno/etune in the future. I imagine that the way the reflash tune has the ignition and cam angles set is probably not bad...? So I have been looking at the fuel tables with the AF ratios and want to try to adjust my AF ratios. Now are these tables only used for adjusting fuel at wide open throttle (WOT Lamda Adjustment)? At 3rd gear wide open throttle looks like this...
Running rich as expected from a generic Reflash tune. The suggested change tabe looks like this...
Now if im understanding this correctly all of the fuel should be adjusted to try to accomplish the 12.46 AF ratio from the "normal table values"? Is this what the k24z7 likes at WOT?
Here are the corresponding tables for the high cam also:
I really haven't found much information as far as actual tuning with FP Manager. Most of the info I have found relates to setting up the hardware and software, but not much instruction on actually tuning. Am I crazy for wanting to figure our how to tune with this software? Or just stick with a dyno/etune like everybody else? But then where did these guys learn!?
