Inspection problems with K tuned Downpipe
Results 1 to 10 of 24
Thread: Inspection problems with K tuned Downpipe
    Mar 2017
    3
    Hey guys,
    I have a 12' civic si, with a k tuned downpipe with high flow cats. I failed the inspections in NJ, and was wondering whether the problem was due to the downpipe or if it was because of flashing the ecu with hondata. Any help would be greatly appreciated, thanks!
    Inspection problems with K tuned Downpipe-img_5762-1-.jpgInspection problems with K tuned Downpipe-img_5761-1-.jpg
    Big Timer!!! kevvo21's Avatar
    Sep 2016
    Toronto, Canada
    217
    is it because your secondary o2 sensor is disabled? you may have to enable it, drive carefully and slowly to the inspection place, so the CEL doesn't come on. that's just my guess
    2014 DBP Si Sedan
    "Drop a gear & disappear"
    Feb 2019
    NOVA
    16
    I know this is an old thread, but check your area laws on how many "not ready" are allowed for it to pass. Here in NOVA, we are allowed 1 "not ready."
    Oct 2018
    11
    I just went to get my car inspected In NJ and failed with my catted k tuned downpipe. My tuner looked at the data and everything is enabled but when fp hooked up to car with laptop, it says my cat and o2 sensor is not ready. What do I do?
    1,141
    Quote Originally Posted by Soldier1288 View Post
    Have you reset the battery or cleared codes recently? Sensors showing not ready usually means you need to drive it for a bit.
    Oct 2018
    11
    Nope, my tuner asked the same thing, so I should drive it and push on it before heading to the dmv? He told me to push on it so the car can recognize that there is a cat., told me to try to drive 100 miles then go
    866
    Some have had trouble getting it to set regardless of mileage. If they don't set you will need to remove the dp and/or flash back to stock calibration.
    Similar topic here, this person was catless though
    https://r.tapatalk.com/shareLink?url...0&share_type=t
    Another one here
    Oct 2018
    11
    What do you mean set?
    866
    Use your flashpro to view your obd readiness monitors. If any are not set or complete it means the ecu is still waiting for feedback to confirm the emissions equipment is functioning properly. Until then you cannot pass an emissions test.
    Click obd diagnostics, then readiness tab.
    Oct 2018
    11
    So my obd2 diagnostics is saying it’s not complete, and under supported it says yes under o2 sensor, evaporative system and catalyst monitoring. All three are under incomplete. How do I change that thru flash pro?
  1. RV6 catted downpipe + K-Tuned axle-back?
    By 62953 in forum Exhausts and Downpipes
    Last Post: 06-05-2017, 09:29 AM
  2. UR racing and K-tuned downpipe installation question
    By BlackCivicSI2013 in forum Exhausts and Downpipes
    Last Post: 02-17-2017, 07:18 PM
  3. K-Tuned 3' Downpipe?
    By VtecKickedInYoo in forum Exhausts and Downpipes
    Last Post: 09-28-2016, 01:12 PM
  4. Skunk2 Downpipe with Flashpro - Failed NY Inspection
    By sirthanh in forum Mechanical Problems & Technical Chat
    Last Post: 06-19-2014, 02:10 PM
