Boost and AFR gauge harness
Like Tree5Likes
  • 2 Post By wsenefeld
  • 3 Post By wsenefeld
Thread: Boost and AFR gauge harness
    Nov 2014
    WV
    376
    Im having trouble locating a suitable spot to run the harness from inside the car to the engine bay. Were should I be going through the firewall? Ive never installed any gauges before. Thanks
    2015 Civic Si Turbo Sidewinder/Hood Exit 450+ whp
    1991 Nissan Skyline R32 GTS-t (bolt ons, untuned)
    __________________
    9GensoSiety WV (recruiting new members)
    Platinum Member mreggball's Avatar
    Jan 2015
    Eastern PA
    2,063
    I'd also like to know this, for a different application.
    POP CREW MEMBER #615
    Retired:
    2012 Civic Si sedan / Dyno Blue
    2014 Civic Si sedan / MSM
    2012 Civic Si sedan / Sunburst Orange
    2007 Civic Si sedan / Silver
    Big Timer!!! wsenefeld's Avatar
    Sep 2015
    Indiana
    272
    If nobody answers you before Tuesday, I'll try to let you guys know. I'll be installing boost and afr guages then and let you know the route I went and how well it worked.
    slee0730 and RujoKinJal like this.
    2015 Civic Si sedan - dyno blue pearl
    FlashPro tuned on E85 by VitViper
    PRL stage 1 turbo kit
    Garrett GTX3071R
    DeatschWerks DV2 1200cc injectors
    DeatschWerks DW65c fuel pump
    Full Race exhaust
    Hasport 70a rear motor mount
    Hasport 62a side mounts
    Enkei PF01 18x9 +45
    Buddy Club Sport Spec coilovers
    Eibach 24mm front sway bar
    Godspeed 24mm rear sway bar
    Skunk 2 rear camber arms at -1°
    Eibach front camber bolts at -1°
    5% tint
    Jan 2015
    Eastern PA
    2,063
    Thanks dude
    Retired:
    Big Pimping!!! Lunch_Money's Avatar
    MD
    864
    Don't most people just run it through the rubber grommet on the driver's side behind the clutch pedal?
    2013 PMM Si Sedan
    Sep 2015
    Indiana
    272
    Installed my PRL turbo kit today and I ran both the AFR and boost guage through the huge gromit/boot that the steering rack goes through. I just poked a small hole in the gromit with my knife and pushed them through. Painless.
    slee0730, mreggball and RujoKinJal like this.
    Garrett GTX3071R
    Full Race exhaust
    Enkei PF01 18x9 +45
    5% tint
  1. Is anyone running a boost gauge? Where did you mount?
    By lsvtecturbo in forum Forced Induction And Nitrous
    Last Post: 02-08-2016, 10:26 PM
  2. Boost gauge shows 4 psi more than the map sensor
    By JoseCoronaMX in forum Forced Induction And Nitrous
    Last Post: 12-25-2015, 08:53 PM
  3. Boost gauge on CT supercharger
    By Bamboost in forum Forced Induction And Nitrous
    Last Post: 12-02-2015, 08:44 PM
  4. Spark plugs for boost / MAP sensor for boost
    By UTAH TSX in forum Forced Induction And Nitrous
    Last Post: 01-22-2014, 11:29 PM
