Need Help Passing Inspection CT SC'd Catless - Page 2
Results 11 to 15 of 15
Thread: Need Help Passing Inspection CT SC'd Catless
    1,191
    Quote Originally Posted by 9thgenBae View Post
    Damn so i am pretty much screwed unless i can find a shop that doesnt care or doesnt realize the 2 checks are incomplete. And by what youre saying, even getting a catted downpipe installed will not help me at all due to aftermarket MAP and the tuning correct? Its getting to the point where i wish i could just swap the downpipe and pass. I really dont want to go back to NA just to pass
    If you can get the 02 sensors to work with a catted downpipe then you should be ok.
    One Bad Mama Jama!!! BWill9886's Avatar
    St. Louis, MO
    399
    Hey, if you can find a shop that plays loose like that more power to you.
    But yes, having a cat really only helps you if you have to pass a sniffer test (and obviously it helps with not throwing secondary o2 codes).
    Good luck to you and let this be a cautionary tale for anyone else living in an emissions area. Consider these issues in advance, rather than waiting until the last minute!
    2013 RR Si Sedan - Modified RSX/8th gen CT-E supercharger and 2.25" IMT aftercooler
    1,837
    Quote Originally Posted by BWill9886 View Post
    Anyone attempting this should be VERY careful and be ready to have flashpro open to check all your vitals. Having the supercharger still on there throws off airflow the engine is expecting to see. Especially if you have an aftercooler. You do not need to mess with the fuel pump though. Works 100% fine in a stock car given how the fuel system works.
    I may be wrong, but I assumed that the supercharger essentially becomes an intake manifold if it's always in bypass mode. The engine should be able to adjust to any difference in air cubic volume change, due to the difference in it versus the stock intake manifold. I've heard multiple people doing this safely, in order to get inspected.
    Now, I do agree that first startup, I would be watching with flashpro and a laptop. lol.... I'm paranoid about my Si! Love the thing way too damn much.
    Vit Tuned with Flashpro
    Continental Extreme Contact Sport Summer tires 245/40-17
    Buddy Club Sport Spec Coilovers
    Ultra Racing 3 point Trunk Brace
    FKX Racing Rear Strut bar
    Nooblets dath1974's Avatar
    Apr 2014
    40
    I have personal experience with this. . . I gave up on defouler and all that as I got the same "slow response" code back... I also had a lightweight flywheel, so I *had* to disable misfire detection. Both items cause a failure. I ended up buying a new catted downpipe from Fullrace and going to a FX400 clutch / full weight flywheel... The downpipe is easy enough to swap out for offroad use.
    I know this isn't the least expensive solution, but it worked for me and with all the money I already had invested in my build, I was just being stubborn trying to figure out ways around this. WAY better than going back to bone-stock! I don't see how you'd get by without a cat (and regular flywheel if you'd swapped to a lightweight).
    St. Louis, MO
    399
    Quote Originally Posted by dath1974 View Post
    What are your emissions requirements? What flashpro settings did you run?
    Most of us cannot run maps that would allow for even an aftermarket downpipe to be run safely due to throwing off fueling.
  1. passing emissions inspection
    By bumpingblack13si in forum ECU Tuning
    Last Post: 06-13-2017, 12:17 PM
  2. best cai for ct sc
    By bumpingblack13si in forum Forced Induction And Nitrous
    Last Post: 04-19-2014, 10:34 AM
  3. Passing NYS inspection
    By x0 R3lApSe in forum North-East
    Last Post: 09-30-2012, 10:44 AM
