The Official: Q&A for the CT-E Supercharger Kit - Page 360
Page 360 of 360 FirstFirst ... 260310350358359360
Results 3,591 to 3,596 of 3596
Like Tree1058Likes
Thread: The Official: Q&A for the CT-E Supercharger Kit
  1. #3591
    Jul 2016
    87
    Quote Originally Posted by BWill9886 View Post
    Looks good. Torque curve is nice and flat. Looks like ambient temp was much higher on the 2.95" pulley. I'm sure the car will feel even better in the cooler temps.
    Did you retune for the smaller pulley? Afr is a bit more lean compared to the 3.6" run.
    Quote Originally Posted by Toby.Kourtney View Post
    I retuned for E-40 which according to my tuner can run more lean without risk of detonation.
    If anything the 3.6 pulley run was too rich. Looks like a Vit tune, but he is usually better at keeping the AFRs more consistent. I'm pretty sure he did that to be extra safe because of how bad those high IATs are for detonation.
    2.95 is still right around 12:1 which is usually where you want it. Definitely would have tried to bring that area around 3000 RPM down, but if she ain't knocking it's all good.
    Does anyone have a stock or fbo datalog of a 3rd gear wot for a e-dyno comparison? I was super excited to do a comparison from before the blower, then overlay it with a 3.6 and 2.95 but can’t find my stock datalog anywhere.
    When I get on my laptop later I'll send you my old mild bolt-on one.
    Thank you
  3. #3592
    Jul 2016
    87
    Here's a comparison between a 3.6" pulley in red, a 2.95" pulley with IMT charge-air-cooler in green, and Bwil's mild bolt on in blue. It seems the blower with the 3.6 " pulley doesn't seem to make much more power then na til after 5000 rpm. The 2.95" pulley definitely shines in the midrange. It made 100 lbs/ft of torque over the 3.6" pulley at 4700 rpm, but then starts to drop after and the 3.6" has a flat torque curve the entire pull. At 7000 rpm the 2.95" has 50 more torque then the 3.6".The Official: Q&A for the CT-E Supercharger Kit-stage1_stage_3_fbo.jpg
    BWill9886 likes this.
  4. #3593
    890
    Is it dropping boost in the upper rpm? Maybe the blower is losing efficiency at that rpm?
  6. #3594
    Jul 2016
    87
    It was dropping boost before.I tightened the belt. I loaded the datalog with no belt slip for the comparison. With the belt tightened it only made 10 more whp at 9.5 psi.
  7. #3595
    4
    I'm looking for a 3.6" or 3.15" pulley for my CT kit. Anyone know where I can find one?
  8. #3596
    Jul 2016
    87
    Quote Originally Posted by Greg9thGSi View Post
    https://pulleyboys.com/cart/comptech...ar-pulley.html
  1. Kraftwerks Supercharger kit
    By FXRob in forum Forced Induction And Nitrous
    Last Post: 07-23-2012, 02:58 AM
  2. OFFICIAL: Rap & Hip-Hop Thread
    By wattskee in forum Water Cooler
    Last Post: 07-16-2012, 02:27 AM
  3. Replies: 22
    Last Post: 01-09-2012, 02:37 PM
