Fuel tank size?
Page 1 of 7 123 ... LastLast
Results 1 to 10 of 69
Like Tree16Likes
Thread: Fuel tank size?
    Member SaugaSI's Avatar
    Jul 2011
    52
    fill up....gas tank ques
    hi everyone,
    i recently noticed that when i was filling up the nozzle stopped but i was still able to fit in an extra 6 liters.......im thinking i probably shouldnt have kept going......anyways, anyone know if it is okay to fill up more than when it stops on its own?
    Digger likes this.
    Member
    Morgantown, WV
    77
    6 liters (1.5 gallons for us in the states) seems a bit much to go in after the automatic shutoff, but I'd say as long as there's not a puddle under your car there's no problem with topping off. Someone might have a different opinion, but I don't think there's a bad spot where the fuel could be going.
    Digger likes this.
    Elder Member Clintro's Avatar
    Aug 2011
    Tampa, Florida
    335
    Probably ok.... IMO as well.
    Big Pimping!!! stringfellowhawke's Avatar
    Tampa, FL
    896
    You should be fine as long as you dont top it off to the point where the gas is almost coming out and overflowing, but wouldnt make a habit of topping off. I did find this. "Extra room in the gas tank is needed for the gasoline to expand. Topping off can cause the extra gas to overflow into your vehicle’s vapor collection system. Best case scenario is that you’ve wasted more gas, worst case scenario is that you have fouled up your car’s vapor system. The fuel in the vapor collection systems will also cause your car to run much less efficiently, another waste of fuel and money."
    Krayjee likes this.
    2012 Honda Civic LX
    Dyno Blue Pearl
    Ado
    Ado is offline
    Junior Member Ado's Avatar
    Jul 2011
    25
    I always top my car off, rarely (but occasionally) to the point that it overflows a little. Five bucks says the pressure discharge is just a check valve, which a few drops of liquid gasoline wouldn't hurt any more than the gasoline vapor that normally discharges through it.
    Digger likes this.
    9thgen's Official E-thug CivicMx's Avatar
    Aug 2011
    Massachusetts
    1,719
    why do you need to fill up your tank so much... i always fill mine 3/4 of the way... the car feels too heavy when is all filled up
    CiViCMX | 9thNorthEast Crew Member #001 | K24Z7 Crew Member #617
    Join 9thNorthEast here:
    Junior Member
    Fuel tank size?
    Hey everyone. I am at a bit of a conundrum here, as my fuel tank is acting... weird. In the manual, it states that the Civic LX has a 13.2 gallon tank, however whenever I fill up, the max I can hit is maybe 11.5 when it hits automatic shutoff. Now, each time I have filled up, my tank empty light is on, so I know I'm nearing the end (at about 15-25 miles left on the iMID). Where is the extra ~2 gallons? I know of some cars having a reservoir for a little extra gas, but I'm not sure if there's an imbalance somewhere or whatnot. Thanks for any insight provided.
    2014 January FB2/FB6 ROTM Marchael's Avatar
    May 2011
    Houston, TX
    1,937
    That is a bit odd. Maybe that two or so gal is like a buffer, space to prevent overflow maybe?, iunno. But maybe. Im also gonna see how mine is too cuz i have an lx ready to pump again.
    2012 Taffeta White LX Sedan
    Member ID: 926
    FB2 Squad #22
    R18 Crew #549
    MY GARAGE
    2014 FB2/FB6 JANUARY ROTM Winner
    2013 FB2/FG3 JANUARY ROTM Winner
    Junior Member
    Jul 2011
    19
    Must be reserve gas. Trust me, when your computer hits 0 miles left your car is not out of gas. I've taken it way pass that and didn't get stranded. I wouldn't push it though. Do not drive more than 40 miles after your computer tells you that your out-of-gas.
    Jul 2011
    1,339
    ~2 gallons are on reserve, which is why filling up tops off at ~11 gallons instead of ~13 gallons. More information can most likely be found in the owner's manual.
  1. Aluminium Tank Lid
    By aritect in forum Coupe
    Last Post: 11-03-2012, 02:11 PM
