Automatic Transmission Fluid Change - Page 4
Page 4 of 4 FirstFirst ... 234
Results 31 to 36 of 36
Like Tree7Likes
Thread: Automatic Transmission Fluid Change
  1. #31
    Nov 2018
    OKLAHOMA
    94
    Quote Originally Posted by highness View Post
    Got the B123 code late last week. Called the dealer to see what they charge for the fluid change - $240.
    So I finally had the time to do the transmission fluid change this morning. Bought my car as a CPO with 40K miles (it now has 60K) on it and would have assumed that the dealer did the CVT fluid change much earlier - but I don't think they ever did.
    When I replaced the fluid this morning, I only got a little over 2 quarts out of the transmission. When I filled it back up, it took about 3.5 (before it started spilling some out of the overflow hole). Pretty sure I don't have a leak (the underside of the pan and engine) was pretty clean - so I have to believe the dealership never checked it.
    It now shifts much more smoothly than it did when I bought it.
    I didnt wait for my MM to get the code, I changed the transmission fluid at around 35,000 miles along with the brake fluid at the Honda dealership. Both transmission and brake fluid change cost me around $180 with tax included. Most of you probably surprise why so cheap? I received emails from my dealership and coupons on a monthly basis for 15% off any service. Also, I was told by the salesman when I bought the car to install the dealership app to check for coupons so I would suggest doing that before paying premium price for getting any service done at the dealership
    2015 HONDA CIVIC SEDAN LX AUTO
    MODERN STEEL METALLIC
  3. #32
    Big Timer!!! Killmonr's Avatar
    203
    I went to the parts bought 4 qts of atf cost me $49. Drain and fill. The 9th gen has a filter internal not really serviceable. I do mine every 30 k. Says in manual take 3 changes to get all fluid out. I seen my reminder i just keep doing it every 30k. Got 170k on car
  4. #33
    Aug 2019
    13
    I know that I need to change washer on the drain plug but do I need to change the washer on the check bolt also? if so what is the part number?
  6. #34
    2,721
    Quote Originally Posted by joshua2395 View Post
    Always a good idea to replace the aluminum crush (sealing) washers when changing oil/fluids.
    That said; I have reused both drain plug and fill plug washers, if they are not overly distorted or compressed.
    About 15 years ago I started using a thread sealant on engine and transmission drain/fill plugs; because the manufacturer of the bike recommended using it
    https://www.permatex.com/products/th...hread-sealant/
    Not only does it seal the threads it acts as a mild locking agent, so even if the plugs are not torqued to spec, they will not loosen. This has been my experience anyway; your choice.
  7. #35
    Aug 2019
    13
    Do you know the part number for the check bolt washer?
  8. #36
    2,721
    No.
    Need to know year and model car.
    Check here: https://www.hondapartsnow.com
  1. 1st Engine Oil Change and Transmission Fluid Change Impressions
    By northwoodshyun in forum Mechanical Problems & Technical Chat
    Last Post: 01-06-2018, 04:30 PM
  2. Transmission Fluid Change
    By Roadcourse in forum Mechanical Problems & Technical Chat
    Last Post: 10-31-2013, 04:17 PM
