2012 with only 15k miles- tranny fluid/coolant/brake fluid/spark plug change needed?
Results 1 to 10 of 10
  • 1 Post By KDiggityDog76
Thread: 2012 with only 15k miles- tranny fluid/coolant/brake fluid/spark plug change needed?
    Nov 2013
    12
    My daughters 2012 has only 15k miles, and based on miles obviously doesn't need transmission fluid, coolant, brake fluid, or spark plugs changed. BUT it is over 3 yrs old...does that require theses services be done regardless of mileage? If you follow the owners manual service recommendations, they should be done. Seems somewhat wasteful to me. Thoughts?
    Platinum Member EffBee6fromthe209's Avatar
    Jan 2013
    209 cen cal
    8,198
    What model?
    Nov 2013
    12
    2012 EX-L sedan with automatic
    Jan 2013
    209 cen cal
    8,198
    Change the fluids on tranny and coolant.leave the plugs unless you detect bad driving or a misfire like drive
    I Drive Too Much 9GenSi's Avatar
    Cold Michigan
    4,526
    Same advice as EffBee, leave the spark plugs alone and replace the fluids and you will be fine. My plugs looked fine at 92,000 miles when I changed them out. It never hurts to change fluids every few years no matter how many miles you have driven.
    2012 Civic Si Coupe CBP
    Freedom and Liberty For ALL! (some restrictions apply, must be over 18, not available in some states)
    K24Z7 Crew Member #30
    High Milers Club Founding Member
    Nov 2013
    12
    Should I change the brake fluid also?
    Jan 2013
    209 cen cal
    8,198
    I would leave be,unless and only unless that low mileage is from hard city abuse.major stop and go traffic.then yes change it.otherwise.no.I haven't changed mine in 115k miles or nearly 3 years.
    Big Pimping!!! KDiggityDog76's Avatar
    San Diego, CA
    962
    Brake fluid needs to be changed at two to three years even if it's not being used hard due to the hygroscopicity of the fluid. The moisture building up is not good for several components of the system. A fluid change is the best way to get rid of that moisture. Don't forget to get into the ABS a good bit prior to changing brake fluid.
    Official K24Z7 Crew #372
    Teeps likes this.
    ~Sure you could buy an Si and leave it stock, but that would sorta be like paying for a prostitute just to talk~
    Nov 2013
    12
    What do you mean by getting into the ABS?
    San Diego, CA
    962
    Brake so hard that the ABS pump actually begins to pulse. It will push old fluids out of places it's long lain dormant like Smaug.
  1. 1st Engine Oil Change and Transmission Fluid Change Impressions
    By northwoodshyun in forum Mechanical Problems & Technical Chat
    Last Post: 01-06-2018, 04:30 PM
  2. Transmission Fluid Change-SI Manual Tranny
    By Steve H in forum Maintenance/Repair and Practical
    Last Post: 08-26-2017, 01:17 AM
  3. ATF change @ 15k miles
    By Mikenj in forum General Maintenance
    Last Post: 08-03-2014, 04:58 PM
  4. Auto Tranny Fluid Change
    By Roadcourse in forum General Maintenance
    Last Post: 09-07-2013, 08:23 PM
