when replace water pump? (was Dumb question]
Results 1 to 10 of 18
Thread: when replace water pump? (was Dumb question]
    Big Timer!!! Killmonr's Avatar
    220
    At what mileage or age should you replace the water pump? 12 civic ex 1.8l?
    744
    When it starts leaking or making noise.
    Follw me on IG: fl_fg4
    205 whp
    174 wtq
    Platinum Member fear24's Avatar
    KCMO
    1,495
    what he said above!
    if you regularly maintain your car, follow the maintenance schedule closely (doesn't have to be exact), your car will give you years of mostly trouble free service. you abuse it...you ignore things, you will have problems.
    don't let dealer tell you that you need to replace your timing belt....cause your car has a chain and it never needs replacement.
    POP Crew #61
    2014 Black EX
    20% Global Tint
    Curt 1 1/4" receiver
    Weathertech In-channel visors
    2,768
    Good question.
    As was said above when it leaks or starts making noise.
    That said: I will probably replace the water pump in my '12 Civic at 10 years.
    When I replace accessory belt & tensioner.
    Honda flat rate time for the water pump is 1.5 hours.
    Roadcourse and Ridingaround like this.
    220
    Thank you all for all your help. sounds good to me.
    MZN
    MZN is offline
    Greenhorn MZN's Avatar
    Santiago, Chile
    24
    Quote Originally Posted by 12FG4Rallye View Post
    when they say "when it starts making noise" what kind of noise? I have a SI 2012 and when I accelerate it I feel a noise like whistling.... Do you mean that kind of sound?
    744
    Quote Originally Posted by MZN View Post
    Have you checked for any water dripping/leaking from or around the pump?.The sound can be a mix of chirping like a belt squeak and some grinding/knocking sounds which is all a sign the bearing has gone.
    205 whp
    174 wtq
    220
    I would check all of above. I didnt see my leak till i took water pump off car. The car was overheating and I replaced everything. Raditor, temp sensor, thermostat, hoses and fluid of course.
    MZN
    MZN is offline
    Santiago, Chile
    24
    The sound that my SI has is like a whistle that you feel when you accelerate the car.
    It's a whistle as if it were a little "super charger" accelerating ... to explain it in some way
    Maybe this sound on my SI it's "normal"?? Maybe all the SI sounds the same way
    744
    Do you have any mods?
    205 whp
    174 wtq
  1. want to replace water pump
    By jvic65 in forum 9th Gen Civic General Chat
    Last Post: 08-06-2018, 05:22 PM
  2. Replies: 18
    Last Post: 02-05-2016, 06:54 PM
  3. Oil pump conversion balance shaft delet using k20a2 oil pump PRB or RRC
    By UTAH TSX in forum Forced Induction And Nitrous
    Last Post: 01-27-2016, 09:15 PM
  4. Water pump
    By Long0709 in forum General Maintenance
    Last Post: 11-23-2015, 02:17 PM
  5. Aftercooler Water Pump Wiring Help
    By KHashi in forum Forced Induction And Nitrous
    Last Post: 08-19-2014, 08:34 PM
