Cheapest DIY intake I've seen.
Results 1 to 10 of 10
  • 2 Post By mvance30
  • 1 Post By Civi9
Thread: Cheapest DIY intake I've seen.
    Sep 2015
    62
    I've been toying with getting an intake for my SI for awhile now but honestly although I could afford the $350 for a new one, I don't feel justified spending that kind of money when really besides the noise, they're pointless and even show on some dynos to make you lose a bit of HP (without a tune). So browsing all the DIY threads on here I saw a lot of good choices. But they still involved spending a decent amount of money.
    I bought a whole stock intake from a friend who upgraded his on his car. Cost me $25 bucks.
    I did this.
    http://i.imgur.com/uom0nrb.jpg
    http://i.imgur.com/WBJSukD.jpg
    (for whatever reason I cant embed these images)
    I have to fab up a bracket and shave down some parts a little more but besides that it does its job well. Above 4k and especially when in VTEC it sounds great, cant notice a difference it or any other intake only 9th gen i've heard. Also looking at the intake temps I don't notice much if at all of a temp change of the air. Granted I've only tested it for 20-30 minutes and its pretty cool out right now. I'll datalog on my 30 mile commute tomorrow and make sure.
    short clip of it. not the best Mic since its from my dash cam but you get the idea.
    https://youtu.be/h16Lkxdq_tM
    Stigmacher and mreggball like this.
    Nooblets ROWWWEL_808's Avatar
    Feb 2015
    Maui, HI
    58
    You will be experiencing a lot of heat soak with that set up. The intake is just going to be sucking in hot air the whole time. Might not be as bad depending on the climate where you are but here in Hawaii where temps never really drop below 60 degrees there would be a noticeable difference. Just my 2 cents.
    2016 Focus ST. All stock except Exhaust Resonator Delete.
    2012 CBP Si Sedan. SOLD.
    Invidia Q300 Catback Exhaust, Rv6 Catted DP, Takeda Momentum Cold Air Intake.
    Tein Street Advance Coilovers, D2S 3.0 Projectors 6000k.
    Sep 2015
    62
    I figured as much but my data scanner isn't showing higher temps.
    Also besides a heat shield, what would cause this set up to be any worse than a proper CAI?
    1,835
    The way you have it set up is like an SRI. You could make it more like a CAI if you ran some aluminum tubing where you have the filter, down behind the drivers side foglight. You need to remove the resonator to do this.
    mvance30 likes this.
    Vit Tuned with Flashpro
    Continental Extreme Contact Sport Summer tires 245/40-17
    Buddy Club Sport Spec Coilovers
    Ultra Racing 3 point Trunk Brace
    FKX Racing Rear Strut bar
    Sep 2015
    62
    Click image for larger version.
    sorry I did know that just had a brain fart. I'm not sure if I trust taking air in from down there. I know plenty of people who haven't had any issues but I did notice when I took my panel filter out (12k on the car) there was a decent amount of crud built it from the inlet side coming from down there. Theres no oil and crud in my intake pipe so I'm not sure whats going on with that. When I take out the rest of the piping I'll take a look.
    1,835
    I bought the AEM CAI, which should be coming in today. I'm switching from my current K&N intake to the true CAI. I love my K&N, but plan to supercharge with CTE kit, so need a true CAI for that setup.
    I understand your reservation about where the filter will be located, but AEM and PRL both have their filters sitting there. It seems to be the best place for a true cold air intake filter to sit. I plan on using a hydro shield for my filter, as well as closing off the holes in the underbody panels.
    Myx
    Myx is offline
    Oct 2014
    133
    Quote Originally Posted by mvance30 View Post
    If your scanner is not showing higher temps than stock then you are golden. Great job! And it sounds great. Thanks for sharing.
    What are you looking at for a scanner? Torque app?
    Kevin
    2015 Honda Fit LX CVT
    Sep 2015
    62
    Quote Originally Posted by Myx View Post
    Docooler New Version V1.5 OBDII OBD2 Bluetooth Car Diagnostic Interface Scanner
    with torque app.
    Sep 2015
    62
    Cheapest DIY intake I've seen.-12931016_10156714742420006_7428739555356800245_n.jpg
    This is what I was talking about. 12k miles on the filter and it looks like this? Its a little concerning considering I've changed two filters in other cars last month one with 36k on it and one with 74k on it (yea I know smh) and both were dirty equally across the filter and had less dirt.
    Apr 2018
    I know this thread is old but. Thanks. Will be using this idea.
  1. Cold air intake DIY for Si.
    By N8vSi in forum Performance
    Last Post: 06-17-2018, 08:36 AM
  2. Another Short Ram Intake you can DIY
    By towncaptain in forum Performance
    Last Post: 12-19-2015, 07:45 PM
  3. DIY Short Ram Intake- ART clone
    By 13Si-vtec in forum Intakes and TB Spacers
    Last Post: 10-08-2013, 12:08 AM
  4. Cold air intake DIY for Si.
    By N8vSi in forum Intakes and TB Spacers
    Last Post: 02-24-2013, 02:26 PM
