Cruise control cuts out - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
Thread: Cruise control cuts out
    16
    Intermittent problems are difficult and frustrating for both you and the dealer Tech trying to diagnose it.
    You can throw parts at the problem based on educated guessing: brake and clutch pedal position switches, the main set/resume/cancel switch, etc... but that will get expensive quick.
    Are you positive the cruise control cancels, then resets without an input from you?
    You mention the problem occurs on rough roads. How repeatable is the problem under rough road conditions?
    It definitely cancels. I can occasionally restart it by pressing "set", but more times than not I need to wait 10 -20 minutes before I can reset it. I wish it happened every time I hit rough roads, but it doesn't. Very frustrating.
    16
    Quote Originally Posted by fergy016 View Post
    If I had to guess, I would check the ABS sensors. If they were tugged on when changing brakes, they might be the cause. This would usually prompt an ABS light on the dash though.
    Are there any CEL/ABS lights to help diagnose the issue? Also are you going above 35 mph when attempting to set CC? (I didn't read the old posts, so pardon me if this is a broken record).
    Nope, no CEL, ABS, or any other lights on the dash...other than the cruise control! Yes, going over 35 mph.
    2,738
    Do you have a volt/ohm meter?
    If so test the brake and clutch pedal position switches, cheap and easy...
    16
    i do..can you tell me how to do that?
    2,738
    Cruise control cuts out-clutch-b-1.jpgCruise control cuts out-clutch-b-2.jpg
    If you find a bad switch go here: https://techinfo.honda.com/rjanisis/logon.aspx
    Subscribe for a day.
    use search terms clutch switch and brake switch to find the factory test and replacement info.
    16
    Thank you so much!! Now I just need it to warm up so I can test it.
    16
    Wanted to provide an update to help others who may have this problem. Turned out to be the Clutch Switch Assembly wasn't being fully depressed when the clutch is released. This explains why the cruise would cut out on rough roads. The clutch pedal would move ever so slightly to trip the plunger on the clutch switch assembly.
    Teeps likes this.
    Platinum Member fear24's Avatar
    KCMO
    1,494
    thank you for coming back and updating us all. so many ask for help, it's provided...then never hear if the issue was resolved and what exactly was the issue.
    so, i presume an adjustment on the switch assembly was done and all is good now?
    Teeps likes this.
    POP Crew #61
    2014 Black EX
    20% Global Tint
    Curt 1 1/4" receiver
    Weathertech In-channel visors
    16
    Tried to adjust, but wasn't able to. So, I superglued a rubber ceramic tile spacer to the pad on the clutch pedal and it worked wonders.
  12. #20
    Aug 2019
    Same issue!
    I am having this same issue and took it to the dealer with my 13 Civic SI (stock). The dealer quoted me for replacing the clutch assembly, $1,800. I would LOVE cheaper fix, if it truly is the same thing. The dealer said it was an issue with the clutch being worn, and engaging when it should not during cruise control. Where exactly did you glue the tile? Do you have photos? Is this something that can be done with minimal tooling/knowledge?
    Thank you!
  1. Cruise Control in Rain HELP!
    By KmartSmart in forum Mechanical Problems & Technical Chat
    Last Post: 12-23-2015, 02:16 PM
  2. Cruise Control
    By DVARGS in forum Interior Problems
    Last Post: 05-02-2014, 10:05 PM
  3. Cruise Control installation ?
    By Hazardowz in forum Audio/Video & Navigation
    Last Post: 01-28-2014, 07:35 AM
