Cruise control cuts out
Results 1 to 10 of 22
Thread: Cruise control cuts out
    Sep 2015
    Orlando, FL
    19
    Every so often I'll be cruising down the highway and the cruise control will cut out speed drops and then comes back. Anyone else experience that?
    '13 Civic Si Sedan - daily/family car
    '03 Acura RSX-S - track car
    16
    Can this thread be revived???
    I am having the same issue. Could it be a bad "set / resume" button?
    Any thoughts would be greatly appreciated!
    27,013
    Yes, the thread can be revived. In fact, it is preferred over starting new threads for the same issues.
    Yes, it could be the button. But the only way to diagnose electrical issues is to test each component.
    2,738
    Easiest way to diagnose the problem, is to drive the car with the HDS connected and take a diagnostic snap shot when the problem occurs.
    16
    Unfortunately, I don't have any diagnostic tools. This doesn't seem to be a very common problem, but what I have found seems to point to a bad clutch switch. The switch is possible engaging somehow and cancelling the cruise.
    2,738
    Quote Originally Posted by ASM5150 View Post
    The clutch and brake switches can only cancel the cruise control after a speed has been set.
    A faulty input from either switch cannot reset the cruise control speed.
    What year and model Civic?
    Do you have any electrical mods?
    When did the problem start? days or weeks ago?
    Are the tail/brake lights working properly?
    Intermittent problems are difficult to diagnose.
    Unless there is a symptom pattern failure. In that case your local dealer may know exactly what is wrong; have you called the dealer and inquired about the problem?
    Big Timer!!! aznboi606's Avatar
    Jun 2012
    Atlanta, GA
    182
    I have the same issue with my 2003 Honda accord. I replaced the brake sensor and that fixed it. I'm not sure for the civics tho, I dont have that problem with my SI.
    2012 Civic Si Coupe DBP
    2001 Honda Accord Coupe Blue
    16
    It's a '13 Civic Si that is completely stock. The taillights work with no issues as far as I know. I first noticed this a couple month's ago. It's a very intermittent problem, although it does seem to happen more when the car goes over rough patches of highway.
    2,738
    Intermittent problems are difficult and frustrating for both you and the dealer Tech trying to diagnose it.
    You can throw parts at the problem based on educated guessing: brake and clutch pedal position switches, the main set/resume/cancel switch, etc... but that will get expensive quick.
    Are you positive the cruise control cancels, then resets without an input from you?
    You mention the problem occurs on rough roads. How repeatable is the problem under rough road conditions?
    Super Mod's Pet fergy016's Avatar
    California
    539
    If I had to guess, I would check the ABS sensors. If they were tugged on when changing brakes, they might be the cause. This would usually prompt an ABS light on the dash though.
    Are there any CEL/ABS lights to help diagnose the issue? Also are you going above 35 mph when attempting to set CC? (I didn't read the old posts, so pardon me if this is a broken record).
  1. Cruise Control in Rain HELP!
    By KmartSmart in forum Mechanical Problems & Technical Chat
    Last Post: 12-23-2015, 02:16 PM
  2. Cruise Control
    By DVARGS in forum Interior Problems
    Last Post: 05-02-2014, 10:05 PM
  3. Cruise Control installation ?
    By Hazardowz in forum Audio/Video & Navigation
    Last Post: 01-28-2014, 07:35 AM
