2015 Si - Misfire Issue P0302
Results 1 to 7 of 7
Thread: 2015 Si - Misfire Issue P0302
    Jul 2019
    Sun Diego
    I just bought this vehicle about over 2 months now. Second owner, purchased from a dealership.
    The first time I noticed the issue after a few weeks of driving since purchased. When it was idle from either cold start or normal driving, there was noticeable backfiring from the exhaust. It started to increase as the days passed then one day the TPMS came on, right after I got a CEL and more alerts with Power Steering, VSA. I plugged in my ODBII reader and it indicated P0302 and P0328. Took it to the Dealer and they cleared the codes and did a Crank pattern relearn as explained by the Service Advisor. I drove it off the lot and it seem fine.
    A few days later, that exhaust backfiring starting up again... and what do ya know. All the same codes came back on a week after it started backfiring. So at this point, something else has to be wrong for it to repeat the codes and them just clearing it did nothing to fix the issue.
    Anyone else encountered this?
    Failing a car near you....
    21
    There are literally dozens of reason why a vehicle can be misfiring.
    Take it in for a diagnosis.
    Jul 2019
    Sun Diego
    Quote Originally Posted by DCFIVER View Post
    Took it into Dealership. Their tech did a compression and leak down test and nothing wrong. They are stumped as well. Now they are going to reach out to Honda tech group for more suggestions to help them out. Looks like car is gonna be in the shop for days.
    885
    How many miles on the car? Any modifications?
    P0328 points to the knock sensor. Was this code diagnosed? Check your wiring to make sure nothing is frayed or broken.
    Jul 2019
    Sun Diego
    about 70280 mi. no mods other than cosmetics. code was found using my odb2 and also dealer saw it first time I took it to them. right now it is in their hands to check everything else out since the leak down and compression found no issue and they checked the wires and spark already.
    Jun 2018
    25
    did they swap plugs and coils and injectors to see if the misfire moved? not really sure how a misfire could stump them.
    Jul 2019
    Sun Diego
    Quote Originally Posted by Janz3n! View Post
    Update on that. They have swapped out the plug and coil. So far I have been driving it for about a week now and so far no random misfiring yet. I hope that was just the issue.
