Brakes - Page 2
Results 11 to 17 of 17
Thread: Brakes
    224
    Was the seal that was torn on the caliper (hydraulic piston) or the sliding pin part? Could be loose lug nuts too...easy check.
    Failing a car near you....
    29
    Quote Originally Posted by pimpmypc View Post
    When I hit my brakes the wheel shakes and when I get to lower speeds I hear what sounds like a rough sound. Would this be my rotors? I know the inside camper seal is ripped but not leaking.
    Sent from my iPhone using Tapatalk
    What many call "warped rotors" is actually parallelism. Warped rotors are a misconception spread by ignorant mechanics(past and present) and joe public. While technically it is possibly for the hat of the rotor to warp,it is virtually impossible to warp the disc itself, on a vehicle.
    The brake pad bed-in procedure, quality pads, lug nut torque and proper lubrication of the brake hardware are critical to preventing parallelism.
    Have the rotors resurfaced and replace the pads with a quality pad(Honda,Akebono,Nissin...etc...) Torque the wheels and follow a proper bed in procedure(basically no hard or panic stops for at least 200 miles)
    101
    Quote Originally Posted by 9thgensifamily View Post
    It was on the hydraulic piston but it wasn’t leaking
    101
    Quote Originally Posted by DCFIVER View Post
    The car has powerstop pads and powerstop drilled and slotted rotors. I’ll call around and see who cuts them. Do you have a diagram possibly of the correct grease points and the correct grease?
    Nooblets J9thGen's Avatar
    30
    If your talking about the rubber seal for the pins. They come as a kit sometimes with the pads. Just make sure what's in the box before you buy. And yes warped rotors if it shakes while braking.
    30
    Nvm I take what I said back. Didn't know there was a second page lol. I had power stop before and it felt worse than oem.
    pimpmypc likes this.
    Nov 2017
    11
    Rule number 1 remove wheels and inspect brakes on both sides.
