2012 Hybrid 1.5L AC Compressor Locked
  • 1 Post By 9thgensifamily
  • 1 Post By Teeps
Thread: 2012 Hybrid 1.5L AC Compressor Locked
    Nov 2018
    Hey everyone,
    My 2012 Honda Civic MX 1.5L’s Ac compressor locked. I had a no start condition and it ended up being the ac compressor locking preventing the engine from starting. I have currently bypassed the ac compressor by having a shorter serpentine/drive belt. New compressors go for $600+ and I can’t afford that option currently.
    Is there anyway salvage what I have with a new pulley or bearing or something like that?
    Basically it’s not turning and jammed.
    However I would say functionally that the AC would work if it were not locked and able to spin freely as it were before.
    I’m not sure if it’s possible to just replace the pulley or bearing to solve the issue.
    Again, because this is a hybrid a new compressor costs a fortune 😞
    Thank you!
    Nooblets Aviator6's Avatar
    Charleston, WV
    94
    Sorry, but when an AC compressor locks up, it is due to internal damage and there is no easy fix. Unplugging the electrical connector to the compressor clutch should allow the pulley to spin freely unless the clutch is damaged also.
    2013 Civic Si /// 2019 Pilot EX-L
    225
    I was wondering about the compressor clutch myself, but don't know how all the hybrid stuff works.
    I vote for calling some junkyards, I found a few that can get just about anything through their Network, and handle parts with care.
    Aviator6 likes this.
    2,739
    The hybrid A/C compressor is not a simple component.
    If the internal works have failed. The A/C system will have contamination and MUST either be cleaned of all the debris. Or, contaminated parts replaced.
    Most dealers will not even attempt to clean a condenser or evaporator. Because there is no reliable way to ensure they clean.
