rv6 downpipe exhaust leak?
Results 1 to 10 of 13
Thread: rv6 downpipe exhaust leak?
    Mar 2017
    14
    I installed the catted rv6 downpipe and invidia q300. I also got the car tuned by Steve over at eztunes. It took a while for the tuning process, mostly because I had to stop halfway through and figure out how to get it to pass inspection (I live in NY). After adjusting the defoueler and flashing the ECU to stock, I finally got it to pass. Now I'm running the tune from Steve and I'm not sure if this is normal noise for the downpipe to make or if I have an exhaust leak?
    https://youtu.be/II9NLcpeEeI
    1,146
    Does it do it all the time or just on a cold start?
    Mar 2017
    14
    Sorry I didn't clarify that. It's only on cold start. And it goes away after about 30 seconds.
    1,146
    Mine does the same thing. I think if it was a leak it would make the sound all the time.
    Mar 2017
    14
    Thats what I was reading. That allot of these aftermarket downpipes make noise on cold starts. Just wasn't sure if that's what the noise should sound like? I was also under the impression that exhaust leaks are more noticeable during cold starts. That once the engine and exhaust warms up the noise does down.
    1,146
    Quote Originally Posted by luvbuckets View Post
    Yea I dunno about all that, but the sound yours makes is the same mine makes. Last time I had an exhaust leak it made my car sound like a diesel truck and was more noticeable when it was warm.
    One Bad Mama Jama!!! TenZen's Avatar
    Apr 2016
    376
    Sounds just like my car does on first start up after sitting for awhile. Normal as far as I know.
    2015 Rallye Red Si Coupe
    Acuity Curl CAI, Hasport Torque Mount & Rear Motor Mount, Acuity Shift Linkage & Shifter Base Bushings, Acuity ESCO Shift Knob, BFGoodrich g-Force COMP-2 A/S, FKX RSB/LTB, SiriMoto FSB/RLTB, Full Race Cat-Back, RV6 Catted DP
    180
    I gave up tightening my exhaust all the time. Once the metal heats up and expands, the gap for the exhaust leak is gone. Normally 15-20 seconds. Think my downpipe is good, but the slip on style mid pipe is the culprit.
    Jan 2018
    Winnipeg MB CAN
    104
    my PLM downpipe does the same thing, i think it’s just the nature of the beast.
    Mar 2017
    14
    Thanks for all the input guys. I guess I'll just leave it alone then.
