Spoon brake kit !!! - Page 14
Page 14 of 14 FirstFirst ... 4121314
Results 131 to 140 of 140
Like Tree58Likes
Thread: Spoon brake kit !!!
  1. #131
    Nooblets Gramser57's Avatar
    Dec 2015
    Richmond BC Canada
    77
    Can anybody confirm what the part number is, 45020-MBF-G00 (ACCORD CL7) or 45020-MBR-GOO (S2000 AP1/AP2). I found a good price for these at www.nengun.com and want to purchase soon.
    Taffeta White FB6 Si
    Alpine White E90 330i
  3. #132
    1,837
    I believe that we are supposed to get the S2K Spoon Calipers. Haven't heard anything about accord.
    S2000 - AP1
    Reverse Type
    45020-MBR-G00
    This is off their website you provided. Same part number.
    And YES, that is a great price for them. I may be buying soon at that price.
    Vit Tuned with Flashpro
    Continental Extreme Contact Sport Summer tires 245/40-17
    Buddy Club Sport Spec Coilovers
    Ultra Racing 3 point Trunk Brace
    FKX Racing Rear Strut bar
  4. #133
    Dec 2015
    Richmond BC Canada
    77
    S2000 - AP1
    Reverse Type
    45020-MBR-G00
    Thats what i thought but the S2K calipers are reverse mounted so I am unsure.
  6. #134
    Big Timer!!! homegrown's Avatar
    Feb 2017
    124
    You will want to pay attention to the piston size on the calipers. If they use differential pistons (meaning the leading piston is smaller than the trailing piston), then you will have to not only swap the driver's side caliper to the passenger side and vice-versa, but you'll also have to swap the bleeder screws and crossover pipes (swapping the crossover pipe is a PITA - I've done it on my APRacing CP8350 calipers). You might want to call the vendor and ask some questions; I'm not certain but you might need the MBF calipers that mount to the leading edge of the rotor. Don't say I didn't warn you.
  7. #135
    1,837
    As far as I've been told, the Spoon calipers made for S2k should be a DIRECT bolt-on to our stock rotors. They will not sweep the entire depth of the rotor, but that's not really an issue in itself. I assume that means our rotors are slightly larger than S2K rotors.
    Other 9th gen owners have done the caliper swap just fine.
    My issue is that my current wheels will require spacers to fit them.
    There are correct rotors that fit the Spoon calipers exactly. I plan on getting 2 piece rotors from Team3d when the time comes.
    RujoKinJal likes this.
  8. #136
    Big Timer!!! 305civictyperaw's Avatar
    Sep 2016
    MIAMI, FL
    175
    I’m currently on 18x9+38 advan rg-d2’s whose spokes flare out clearing from my stock caliper.
    Can someone pls help me confirm if spoon caliper would clear this wheel? Thanks
    Miami 9thGen Crew #2
  9. #137
    Sep 2016
    MIAMI, FL
    175
    Quote Originally Posted by Keiththesneak View Post
    The model number on your site is listed as
    45020-MBR-G00. Is this the correct item number? From what I've read this is for the AP1/2 which is a rear mounting caliper. Is that not correct?
    I read on the 9thgencivic FB page, that the correct Spoon caliper for our car is off CL7 part# 45020-MBF-G00. can anyone confirm?
    I also read this caliper will bolt right onto our stock rotor and we can use S2K brake pads
  10. #138
    1,837
    Quote Originally Posted by 305civictyperaw View Post
    There's a template online. It's a silhouette of the Spoon BBK caliper. If you print it to scale, cut it out, you can get an idea if it will clear the wheels by taking a loose wheel and placing the template on the inside of the wheel. If it touches the spokes, it won't fit.
    305civictyperaw likes this.
  11. #139
    Feb 2019
    This is the part number. I installed it on my FG4 with OEM rotors. Just slightly cut the rotor backing plates as the Spoon caliper is bigger than stock.
  12. #140
    Feb 2019
  1. Spoon Subframe Rigid Collar Kit
    By Lek in forum Suspension & Brakes
    Last Post: 02-17-2018, 12:27 PM
  2. group buy for spoon BBK brake kit ?
    By team3d in forum Vendor Deals
    Last Post: 07-24-2014, 01:05 AM
  3. 17" SPOON cr93 !
    By team3d in forum Wheels and Tires
    Last Post: 04-21-2014, 01:17 AM
  4. Brake kits..
    By Apex2Apex in forum Suspension & Brakes
    Last Post: 09-24-2012, 12:47 AM
