Swift Spec R Springs: Prepping & doing it right - Page 2
Results 11 to 15 of 15
Thread: Swift Spec R Springs: Prepping & doing it right
    Oct 2015
    29
    I can confirm they do come with everything needed now, just the one front dust boot. I just had mine installed yesterday. I didn't install rear camber arms, the rear camber is about -1.8 degrees in the rear, which isnt bad.
    Big Timer!!! homegrown's Avatar
    Feb 2017
    142
    I must have done something wrong when I had my Swift springs installed, because I have a horrible creaking noise (like walking across an old wood floor) when going over bumps or turning at low speeds. Shoot, I can get a slight creak just by plopping my fat butt down into the driver's seat.
    The front springs were assembled to new Truhart struts by Chris at Redshift.
    They were fine for the first few months (installed in late March 2019), but now they're really wearing on me. I love the subtle drop and the improved handling, but the noise is a deal-breaker. Considering putting all OEM parts back on.
    Big Timer!!! modrid81's Avatar
    Aug 2018
    Keller, TX
    233
    Sounds like it might be the top hat issue for 9th gens. Take a look at the 14-15 suspension fix thread, where ppl started swapping to 8th gen top hats for the ball bearing set up. I'll be doing that eventually.
    Sent from my iPhone using Tapatalk Pro
    Feb 2017
    142
    Last I read it, we weren’t supposed to or recommended to use any 8th-gen hardware.
    Aug 2018
    Keller, TX
    233
    Well, if you have a warranty. I hadn't seen anything negative on it.
  1. Swift Spec R installed
    By GSX-RBOY in forum Suspension & Brakes
    Last Post: 04-10-2019, 05:30 PM
  2. Swift spec r springs are finally here!!!!!
    By Inurpantz13 in forum Suspension & Brakes
    Last Post: 02-13-2017, 10:20 AM
  3. 12+ Civic Si Sedan Swift Spec-R springs
    By Kmeachy in forum Suspension & Brakes
    Last Post: 06-04-2015, 10:36 AM
  4. Swift Spec R vs Eibach Pro
    By dthom74 in forum Suspension & Brakes
    Last Post: 03-22-2015, 09:12 PM
