Endlinks rotated and popped off - Page 2
Results 11 to 18 of 18
Thread: Endlinks rotated and popped off
    Greenhorn Jessefb6's Avatar
    Southern California
    Thank you all - - i mean it.
    I realize every problem ive been having has to do with the swaybar, i might take it out as well as the black brackets(endlink mounts) on my front coilovers.
    Today, my mechanic took it for a drive and after having it racked up he saw that a bushing had slid off on the swaybar and was causing the clunking. That is fixed now and all is ok. He suggested getting adjustable endlinks if i wish to keep the swaybar. I guess whiteline it is for adjustable front endlinks?
    pic of the bushing missing and the passenger, side how it should be.
    Attached Thumbnails Attached Thumbnails Endlinks rotated and popped off-0be54afa-83b0-497d-a5b3-34b897655c21_1556144476112.jpg   Endlinks rotated and popped off-a5c0992c-e44d-4327-a237-fbd143338c01_1556144495000.jpg
    May 2018
    Los Angeles, CA
    87
    I have Moog front endlinks and bushing. Your bushing are worn out.
    Southern California
    Quote Originally Posted by twoawwsome View Post
    What difference do you feel with moog endlinks or aftermarket endlinks in general, compared to stock?
    May 2018
    Los Angeles, CA
    87
    Quote Originally Posted by Jessefb6 View Post
    I had adjustable rear endlinks from Progress swaybar kit and they suck. They were noisy and no matter how tight the endlinks were tighten, they would come loose.
    The Moog endlinks are much beefier and the bushings are also harder than OEM. I didn't notice a huge change, but the suspension felt tighter and more responsive.
    1,148
    I have the whiteline endlinks on the front of mine. No issues so far. I'm not super low on coilovers tho.
    Southern California
    I was hoping youd say that the ride quality was improved a bit. My car is quite low and im hoping the adjustable endlinks will put an end to my fsb/endlinks issue im sorta having every 2weeks.
    When i rest my foot on my dead pedal i feel a bunch of rattling so much that i rather just rest my foot on the floor mat... i wonder if it’s because of how low i am and a 215/45 tire or once again maybe because of the endlinks being stock and for lack of a better term: flimsy?
    1,148
    I couldn't tell a difference between the stock ones and the adjustable ones. I got the adjustable because the stock ones were popping at full lock down a hill. IMO you have an installer error issue. I'm running 215/45R17 with zero gap and don't have any issues.
    Southern California
    Could it be that when i adjusted the front lower i should have done something more than just rotate the collars? ive been reading extensively about this subject (endlinks install / endlink mounts becoming loose) and im starting to wonder if i needed to do more than just jack it up, take the wheel off, rotate the two collars, n lower it back down 😕
  1. Replies: 15
    Last Post: 12-17-2018, 08:52 PM
  2. VSA and Check Power Steering lights popped up
    By JBcivicSI12 in forum Drivetrain Problems
    Last Post: 04-27-2017, 03:17 PM
  3. Rear Side Panel Popped Off (Not Sure What To Call It)
    By eyi526 in forum Interior Problems
    Last Post: 12-24-2016, 02:31 PM
