ABS Modulator Noise - Page 2
Results 11 to 13 of 13
Like Tree6Likes
Thread: ABS Modulator Noise
    I had my abs modulator changed by the dealer, but the sound is still there only a little quieter. Only happens once when you start the car the pull away.
    I had my ABS Modulator changed by the dealer and the noise is still there but a little quieter. It only happens once and goes away when driving. You only hear it when starting the engine from park and slowly start moving forward, like what pickyowner said. What else can be causing that noise?
    Jul 2015
    4
    Hey i know it a couple years later but i have the same problem, first i was getting the first gear clutch noise- they fixed this by installing a brand new clutch kit. The first gear clutch noise was a damaged spring in the clutch disk and the throwout bearing. This was replaced and clutch is fine. Now i get the 2 secound buzz noise only when i start and restart the ingnition/engine and takeoff for the first time. I dont get a check engine light nor abs light on my dash. The dealer says its the abs modulator but i dont need to change it, it is not normal but it is something i have to live with. Even if they change the modulater which cost 1300$ if might do the same. I will just have to live with this. O well, if somebody got it permanently fixed please let me know
    Civic Si sedan 2012
  1. VTC Actuator Issue
    By skyfox23 in forum Mechanical Problems & Technical Chat
    Last Post: 02-25-2019, 06:03 PM
  2. click noise when braking
    By uni in forum Suspension & Brakes
    Last Post: 01-30-2012, 11:12 PM
  3. squeaking noise
    By my1sthonda in forum Interior Problems
    Last Post: 10-12-2011, 04:05 PM
