Buddy club down-pipe dp !! Summer 2014 ! - Page 2
Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 65
Like Tree30Likes
Thread: Buddy club down-pipe dp !! Summer 2014 !
    You Don't know Me! T_Virus's Avatar
    Feb 2011
    Suck My Tomato, CA
    4,030
    Quote Originally Posted by 95skunkedgsr View Post
    Why does the tubing shrink down inches befor the flang
    back pressure? LoL
    team3d likes this.
    ***08/08/11 - I got my 2012 Rally Red Honda Civic Si Sedan.Hidden Content ***
    *2nd 9thGenCivic.Com Member with a 2012 Rally Red Honda Civic Si Sedan.* 1st is 67cougar.
    - 2012 Rally Red Honda Civic Si Sedan (Current)
    - 2003 Satin Silver Metallic Honda Civic Si Hatchback (Sold)
    - 1994 Pard Blue Green Pearl Acura Integra GSR Coupe (Stolen/Totaled)
    - 1992 Super White Toyota Corolla DX Sedan (Totaled)
    Platinum Member team3d's Avatar
    Oct 2011
    los angeles
    11,031
    Quote Originally Posted by Lunch_Money View Post
    Is there any clearance issues like the Full-Race downpipe?
    no, buddy club is making sure the fitment will be perfect !
    Oct 2011
    los angeles
    11,031
    Quote Originally Posted by T_Virus View Post
    back pressure? LoL
    correct, buddy club dp will have some back pressure.
    Big Timer!!! '13 HFP SI's Avatar
    Jun 2013
    199
    Make sure they include a catted version, I don't want to get screwed for that AND the straight pipe exhaust!
    SiHFPClub Member #33
    K24Z7Crew Member #991
    The name says it all, brand new 2013 Taffeta White Civic SI HFP
    Started with a '99 Civic EX, then a '09 Civic EX-L, now onto the '13 Civic SI HFP
    Can you tell I'm a fan of the civic?
    Oct 2011
    los angeles
    11,031
    sorry, buddy club are not going to offer a catted dp. if you need catted dp, you will need to buy rv6
    Platinum Member KaJeR's Avatar
    May 2012
    2,000
    Cats are for chumps
    T_Virus and Jtciv like this.
    Si HFP Club Member # 4
    330
    You don't need "back pressure " lol
    Oct 2011
    los angeles
    11,031
    your only 1/2 right, less back pressure the better, but when the exhaust pipe is too large, it sometime decrease gas velocity...
    it's cheaper & easier for buddy club just build a 3" straight through down pipe.. this set up is what buddy club tested to be the best cat-less down pipe for a k24.
    same with their short shifter, buddy club R&D test shows full assembly ss kit is better than adapter kit for race application, so they invest $110,000 on tooling for the shifter cage. rather just spend couple thousand on cad drawing & use cnc machine to cut some aluminum adapters.
    Oct 2011
    los angeles
    11,031
    Exhaust Back Pressure Back pressure: The myth and why it's wrong.
    One of the most misunderstood concepts in exhaust theory is back pressure. People talk about it with no real understanding of what it is and what it's consequences are. I'm sure many of you have heard or read the phrase "Engines need back pressure" when discussing exhaust upgrades. Sadly, that phrase is completely inaccurate and a wholly misguided notion.
    1. Some basic exhaust theory
    Your exhaust system is designed to evacuate gases from the combustion chamber quickly and efficiently. Exhaust gases are not produced in a smooth stream; exhaust gases originate in pulses. A 4 cylinder motor will have 4 distinct pulses per complete engine cycle, a 6 cylinder has 6 pules and so on. The more pulses that are produced, the more continuous the exhaust flow. Back pressure can be loosely defined as the resistance to positive flow - in this case, the resistance to positive flow of the exhaust stream.
    2. Back pressure and velocity
    Many people mistakenly believe that wider pipes are more effective at clearing the combustion chamber than narrower pipes. It's not hard to see how this idea would be appealing - as wider pipes have the capability to flow more than narrower pipes. However, this omits the concept of exhaust VELOCITY. Here is an analogy...a garden hose without a spray nozzle on it. If you let the water just run unrestricted out of the hose it flows at a rather slow rate. However, if you take your finger and cover part of the opening, the water will spray out at a much much faster rate.
    The astute exhaust designer knows that you must balance flow capacity with velocity. You want the exhaust gases to exit the chamber and speed along at the highest velocity possible - you want a FAST exhaust stream. (see below) If you have two exhaust pulses of equal volume, one in a 2" pipe and one in a 3" pipe, the pulse in the 2" pipe will be travelling considerably FASTER than the pulse in the 3" pipe. While it is true that the narrower the pipe, the higher the velocity of the exiting gases, you also want make sure the pipe is wide enough so that there is as little back pressure as possible while maintaining suitable exhaust gas velocity.
    Jtciv and missK24 like this.
  12. #20
    Oct 2011
    los angeles
    11,031
    this is a great read about exhaust system...
    exhaustbackpressure
  1. Buddy Club P1 QF Wheels
    By Lemant in forum Wheels and Tires
    Last Post: 07-11-2015, 12:59 AM
  2. Replies: 151
    Last Post: 04-20-2015, 08:12 PM
  3. Buddy Club why me? :'(
    By TJ___90 in forum Suspension & Brakes
    Last Post: 09-01-2013, 11:58 PM
  4. Buddy Club N+ Coilovers
    By FantaSI in forum Suspension & Brakes
    Last Post: 04-26-2013, 05:48 PM
  5. Buddy club coils?
    By kemii'91 in forum Suspension & Brakes
    Last Post: 01-23-2013, 12:39 PM
