Is Tire PSI Change Necessary?
  • 1 Post By homegrown
  • 2 Post By bfaided1984
Thread: Is Tire PSI Change Necessary?
    NJ, USA
    9
    Lightbulb Is Tire PSI Change Necessary?
    Going from the stock 225/40R18 tire to a 235/45R17 tire. Will this require a change in how much air I should have in the tires? Should I keep it at the stock recommended psi?
    2015 Civic Si Coupe Hidden Content
    Big Timer!!! homegrown's Avatar
    Feb 2017
    130
    I'm not certain if there's a hard and fast rule for this.
    Probably the best thing to do would be to set it at the same pressure as recommended from the factory on the door jamb sticker, and adjust as necessary according to the wear pattern on the tires.
    NJ, USA
    9
    Quote Originally Posted by homegrown View Post
    Yea - that's what I've had in my mind to do but then figured if I'm changing tire size then perhaps pressure should change along with it. I've been trying to dig for answers but nothing concrete as come up yet.
    1,063
    I have been in the business of aftermarket wheels and tires for a long time. We always set them to factory specs. Even if we put something huge on like 37x13.50R22.
    scottyrocks and alexaymp like this.
    NJ, USA
    9
    That's exactly what I did. I'll keep an eye on the tire wear and adjust psi as needed.
    Big Pimping!!! Squidward's Avatar
    846
    It depends on the tire you have and what you're doing with it. For most any normal application you can't go wrong with ~30 PSI.
    2013 DBP Si Coupe
  1. 12-15 Stock SI Wheel & Tire/PSI thread.
    By GHOSTMONKY in forum Wheels and Tires
    Last Post: 06-13-2019, 12:23 PM
  2. 12-15 non SI Stock Tire/Wheel/PSI thread
    By nodulw in forum Wheels and Tires
    Last Post: 04-06-2017, 07:22 AM
