Meaty Fitment / Functional Thread - Page 61
Page 61 of 61 FirstFirst ... 1151596061
Results 601 to 605 of 605
Like Tree356Likes
Thread: Meaty Fitment / Functional Thread
  1. #601
    Sep 2018
    Canada
    155
    I need to amend my comment a bit. Since the 2015 came with 225/40/18, 235 is only 1.25% taller.
    I always think back to my 2012 with the smaller stock wheel.
    For me, I'm running the 2012 HFP suspension. For the 2012, I believe 235/40R18 is 3.3% taller than the 215/45R17 tire that I'm going with and also 2 cm wider.
    From factory my new setup will be on a rim that I think is 1" wider (17x8 vs 18x7) and the offset is 1 cm pushed out (+35mm vs +45mm). I really hope I don't have issues without having to roll fenders.
    I should mention I'm getting the Avid.1 AV20 in bronze 17x8 +35mm! That's why I was asking what you were running, dpetro, and hoping you weren't having issues. You still running that set-up?
  3. #602
    911
    Quote Originally Posted by bdubbin View Post
    I no longer have a 9th gen. Driving a WRX now.
  4. #603
    Greenhorn thrustin's Avatar
    Mar 2018
    9
    Quote Originally Posted by W0200320 View Post
    225 on 17x7
    What is you full tire size? I'm guessing 225/45/17 on 17x7 wheels? Are you lowered?
  6. #604
    Sep 2019
    Looks good ! Picked up of the same rim with 235 45r17 federal snows. Going to run them for this winter. In the spring I'm going to switch to all seasons but the size is the question .
    Have been waffling between 235 45 's & 225 45's. The issues I have are :
    Tire stretch with the 225's
    Speed correction with the slightly larger rolling dia of the 235's.
    Thanks for your thoughts
  7. #605
    252
    Quote Originally Posted by Rick M View Post
    I've got 235-45-17 Continental extreme contacts, and the speedometer now matches GPS (maintained on level surface over time).
    There's tire size and speed calculators online, I suggest doing a gps speed vs speedometer difference, then the math for the tires.
    I had known bikes were not accurate at speed. I hadn't thought about why it's a good idea for a car to be going a lower speed than shown.
    IF YOU HAVE A HEAVY FOOT IGNORE THIS.
  1. Thank you thread!
    By jungfenlon in forum 9th Gen Civic General Chat
    Last Post: 10-14-2015, 03:57 AM
  2. Is the 2013 SI Sedan wing/spoiler even remotely functional?
    By MaximumSI in forum 9th Gen Civic General Chat
    Last Post: 10-08-2013, 11:10 PM
  3. Post ***** Thread
    By freddi in forum Water Cooler
    Last Post: 11-12-2012, 07:25 AM
