All Wheel/Tire Fitment & Offset thread - Page 264
Page 264 of 264 FirstFirst ... 164214254262263264
Results 2,631 to 2,640 of 2640
Like Tree1364Likes
Thread: All Wheel/Tire Fitment & Offset thread
  1. #2631
    866
    At stock ride height you can pretty much run whatever. It is not recommended to go anything over 3% larger than stock though. You are going to throw off the speedometer.
    I've seen a few examples of 225/45/18 but they are going to be pretty tall.
  3. #2632
    Greenhorn StephenFB6's Avatar
    16
    Soon lowering my 2014 si sedan on megan racing lowering springs, looking to buy rims as well. Probabaly some Enkei ts6 or some other work te37 reps. I was hoping to be able to fit 18x8.5 +35 for a nice flush fit, do I have to roll fender or should I be fine?
  4. #2633
    866
    Most likely will need a fender roll. May depend on the tire size though. What tire do you plan to use?
  6. #2634
    16
    Probably using 225/40/18 nexens. I think it should be a slight stretch.
  7. #2635
    Big Timer!!! homegrown's Avatar
    Feb 2017
    132
    Quote Originally Posted by StephenFB6 View Post
    You probably will need a fender roll.
    Case in point - I recently had my 2014 Si sedan lowered on Swift springs, with 17x8" wheels on a +37 offset, and they poke out a smidge. No rubbing yet, but I drive very gingerly. Your proposed wheels are ~13mm wider, and coupled with 2mm less positive offset, will poke out 8.5mm more than mine. Well over a quarter-inch is significant.
  8. #2636
    16
    Right on I’ll try to stick with an 18x8 to see if it helps worst case I can roll them, thanks
  9. #2637
    Sep 2018
    Hi all, so I was looking at rims and was wondering if 18x8.5 +44 would fit without any issues? 2015 si, running stock suspension, not sure if I plan on dropping it yet. would I have to roll the fenders?
  10. #2638
    866
    Quote Originally Posted by razgrizaces View Post
    Yeah those will be fine at stock height or mild drop. What tire size do you plan to use? 8.5" wide will probably need something wider than the stock 225.
  11. #2639
    Sep 2018
    Not sure, maybe 235 or 245. What would you recommend if I was running 18x8.5?
  12. #2640
    866
    Upon further review it appears a 225 is approved for 8.5"
    Personally I would consider a 235/40. A little taller than stock But shouldn't cause any issues.
  1. All Wheel/Tire Fitment & Offset thread
    By babycivic201 in forum 9th Gen Civic General Chat
    Last Post: 03-05-2015, 10:36 PM
  2. 18x7.5" rim +40 Offset Tire Fitment Question
    By Heisenb3rg in forum Wheels and Tires
    Last Post: 02-18-2014, 12:29 AM
