21 - 24 of 24 Posts
Eric the car guy on YouTube did a video of this job on his Element with the k24 engine. Almost makes me want to give it a go down the road.
Valve lash inspection and adjustment is a great DIY project. Not the best job for a person with no prior engine work experience.
Access to the valve closet on the 1.8L engine is not difficult and no parts should be needed beyond a couple of dabs of Honda Bond (or equivalent) where specified.
If you have all the necessary tools, the process should not take more than 4 hours. (that's including a beverage break too)
-Spark Plugs (personally I will only run NGK)
-Oil/Filter Change (personally I will use Honda or Bosch D3323 filter)
-Cabin air filter (personally I like Bosch, part# 6029c)
-Accessory belt for PS/AC/Crank pulley
-Brake line flush
-Clutch line flush
-Valve adjustment (as suggested EricTheCarguy is awesome)
Cooling system:
-Thermostat
-Check rubber hoses, replace as needed (cheap insurance)
-Coolant flush/replace
Plus anything the maintenance minder suggests
Discussion Starter #23
-Brake line flush
-Clutch line flush
Cooling system:
-Thermostat
Thank you thank you!
I believe the timing belt should be changed at 90k, so you may want to keep an eye on that.
How in the didn't you know. Si and s2k have chains. Have you ever pop your hood. And or done a proper matenice check haha. Please check your blinker fluid. ?
21 - 24 of 24 Posts
