Mine is a 14. Amazon postings say 13-15.this fits the early 2013 models?
It will fit 13-15 fb6, it will not fit 2012 sithis fits the early 2013 models?
Not everyone wants to build their cars with rare genuine honda jdm parts. Adding some $15 led lights is not the same as replacing the whole diffuser…Gorgeous. But $550!
I opted for switching the reflectors to LEDs on the diffuser. They are pretty sweet. They are two stage - below is with headlights on. Second set of LEDs light up with brakes.
Pretty cheap on Amazon. I got mine for $15 but that particular link is no longer available. Same ones range from $15 to $45 from different sellers. Passed the cables from behind the bumper cover and then underneath the trunk seal, with some electrical tape padding right over the bend.
Of course! Like I said, yours looks gorgeous. I just wanted to share what I've done.Not everyone wants to build their cars with rare genuine honda jdm parts. Adding some $15 led lights is not the same as replacing the whole diffuser…
Hmm.. you may be out of luck for those. I did a quick search on Amazon and nothing came up.@onlyhuman what about 13 si coupe? mine is the same as a 12.
it comes with diffuser, light, light bulb socket, light bulb, light bulb socket adapter with pig tails, you need longer wire to connect to either parking light (like Subaru sti) or brake lightInterested in one. Does it come with the bulb holder, plug, and wiring for the brake light? or is it just the diffuser only? Thanks!
What offset are you running on your wheels?
