I had a ring go on the #4 cylinder. Oil shot out from the breather on the valve cover. Big mess... anyways does anyone know if the k24z7 from the 2012 si will work as a replacement? I know its the same motor but I noticed the ecu part numbers are different. I have a flash pro to accommodate some boltons so it will be retuned.
Thanks
Thanks
