1 - 20 of 31 Posts
So first I want to start off by saying sorry to Eibach for bashing their product. It was not the springs causing the aweful popping noise.
Ok well onto what everyone wants to know. I ordered a bunch of 2011 civic Si parts to use on my 2014 si sedan to test the theory of the plastic bearing we have not holding up to the stress of lowering. I was having the worst luck getting rid of the popping and creaking sounds. This fix should work for coilovers and springs. Here is a list of parts I ordered.
Parts
51402-SNA-903 1 right seat
51403-SNA-903 1 left seat
51722-SVA-A04 2---- not needed
51726-SNA-G01 2 bearing
51920-SVB-A03 2 top hat
90304-S10-024 6 new nuts
The main difference is the 8th gen uses ball bearings to help with friction. The coils are also wound differently. Ours are reversed. So I had to use the right spring seat for the 8th gen on the left(driver) suspension. Fit like a glove. Takes a lot of force to push the bearing onto the top hat. I did not try to reuse the original top hat, the part numbers were different. The bump stops from the 8th gen are longer (do not buy them) I just reused the originals. New nuts because the other were rounded off from repeatedly taking stuff apart. Noise is completely gone.
I'm sticking this for its ingenuity and usefulness to anyone with this issue.
Thanks for the time and dedication, Dan. :thumb:
Thank you so much for this. I'm going to do this I believe. This is just for the front end though, correct? I don't believe I'm having any noises in the back, just the front.
I put all the required parts in the checkout cart and it comes to $190.14
I do not include the bumpstops 51722-SVA-A04 correct? Just wanted to make sure that's the only thing you didn't need. How many miles have you driven on this since you installed all these parts? I had a shop install my suspension so I would be giving them parts and your description on here to explain to them what you did. I just want this noise to go away. If it takes $190, so be it. I also have TruHart Shocks installed on mine. Will these instructions still work or is that only for OEM shocks? Sorry for all the questions.
I haven't tried the Eibach Kit, but I have had the D2 Racing Lowering Springs on now for 3,000 miles and I absolutely love them on my Si Coupe. Better than ANY Honda or Integra that I have ever driven. It is night and day from the stock setup. They are stiff, they are low, they improve the handling immensely, and lower the COG, and the car has almost no body roll. It feels like a track car on the street, and they are totally quiet and it feels great. It lowered the car by 2" in the rear and by 2.5" in the front. It feels aggressive, low, and perfect. :)
Correct you do not need the bumps stops, reuse yours. Don't really need the 6 nuts either, but mine were all rounded off from taking everything apart. Currently at 160 miles since I did this and the noise is still gone. This fix will work for all suspension that reuses the 9th gen top hat.
Thanks for your reply Dan, I will be doing this soon. I will go ahead and buy the nuts just to be on the safe side. Are you using bumpstops that came with your aftermarket springs or still on stock? I Never did install the Eibach bumpstops that came with my springs, I just cut my old ones.
One other question, when you said it takes a lot of force to push the bearing into the top hat, is the mechanic gonna look at me and say "this doesnt fit" or do I need to say, yes it will fit, just push lol.
Discussion Starter #9
I can't remember if eibach supplied new bump stop for the front or if I reused the stock ones. Either way, ust use what's in there now. As for how much force.... I set the top hat on the ground and used body weight to push it on.
Dan, you are THE man!
That is all.
Thank you.
Staff 6 Dan,
Can you confirm that you still have no more noises after running this fix the last month or so?
Discussion Starter #14
Staff 6 Dan,
It has been about 1500 miles since I completed this and the noise is still gone. At one point the noise was so bad I wanted to sell the car. Im glad this conversion fixed my car.
Maybe I'm lazy lol but I'm just now ordering these parts. :(. Noise only comes from my right front. Does that mean I can just order 1 of everything here or do I still need 2 bearings etc? Also, I see you used the new right spring seat to put in left side. Do I need to use the left for the right then? Just trying to see what I need if I'm only doing the right front. Thanks.
Would these parts fit a non si sedan?
Edit: sorry saw your post regarding these parts fitting all 9th gens.
Are those boot bellows side specific? Or are they interchangeable?
Any more confirmations that this fixed the problem for good? Before I spend a couple hundred on parts..
My car just developed the problem at 14,000 kms (~8750 miles) total, about 8,000 kms (5,000 miles) after my Swift Spec R springs were installed.
To answer the above questions, the spring seat/bellows are side specific. From my research for my Swift Spec R Springs.
On the 9th gen (looking down on the spring):
Left is Clockwise/Right is Counter Counter Clockwise
On the 8th gen
Left is Counter Clockwise/Right is Clockwise
All swift spec R springs are clockwise.
The noise still comes back after being driven in the snow and dirt and crap gets up there. It seems to be less severe though. A quick wash of the wheel well gets rid of the noise until it's dirty again. I suspect that I won't hear the noise until next winter.
I have a noise in the front suspention that i suspect may be just that as i have Tein lowering springs... Get on a completely trashed road (let's call it, Beyrut avenue..) no noise. Get on and off sidewalks, no noise. Go on the highway at 60-65Mph and every cracks in the asphalt will go TAC-TAC-TAC-TAC... Very annoying. I will change them for 8th Gen style top plates and bearings if the top plates are diagnosed as defective as i have no doubt those will be more reliable..
Marko!!
1 - 20 of 31 Posts
