921 - 940 of 949 Posts
dyno by Shadman I, on Flickr
212whp/181lb-ft tq
Rv-6 catless downpipe, Q300 exhaust fabricated to a vibrant muffler, P2R throttle body spacer, Vittuned on stock intake.
Do you think a throttle body spacer contributed to your whp figure? It's a cheap mod so I figured I might as well get it too, but only if it makes some gains.
-Factory airbox with TRD Tacoma Velocity stack on lower piping (Ditched the Resonator a long time ago..).
-8th gen crank pulley.
-Skunk 2 downpipe.
-Stock catback with Magnaflow muffler.
-Tuned by Jack @ Jack performance. (K-Tuner)
201.6WHP 175WTQ.
Pig Rich baseline that was cut short at more or less 6700rpm... was getting nowhere... (181.7whp 9.8:1 AFR)
Solid last run 201.6Whp. Fuel [email protected]
What a difference! Night and day!
Can't upload pic for some obscur reason... You don't have permission to access /forum/vbseo.php on this server.
Marko!
214hp 185tq
Ingen cold air
Skunk2 downpipe
Skunk2 full exhaust
Nothing esle
Im in south fl
Not tuned on anything? Thing is probably running crazy lean.
Does anyone know the difference between Mustang Dyno numbers, Dynojet numbers and E-dyno numbers. I just had my car dyno’ed on a Mustang dyno and it isn’t pushing good numbers on the dyno for the mods I have. The car feels way faster than before, but Dyno numbers seem low.
What were your numbers?
With your mods I'd assume somewhere around 215-220whp?
From what I know, typically dyno numbers are slightly over-inflated and edynos are more accurate. So if you're getting low numbers on a dyno, I'd say on a edyno it would be even lower.
In reading, the numbers from an unadjusted Mustang dyno (What I was dyno tuned on) are about 8-12 percent less than a Dynojet (Most dyno’s In the US are Dynojet and seems to be the standard in the US) and 16-20 percent less than a Dynapack (Main dyno in Japan). If this is true, it would give numbers that I am thinking I should be pushing. I will have to see how to get an E-dyno and see what the numbers come out to.
I was expecting around 205-215, but topped out at 195.
Anyone have any insight to this?
that's really under what you should be getting. I'm doing an etune through etunez and Steve said I'm expected to hit around 200whp and all I have is a prl short ram, rv6 catted, q300.
Mods:
PRL 3.5" short ram
rv6 catted
q300
hasport 70a rear motor mount
Tuned by Steve from Etunez
Steve recommended that I use the VirtualDyno software (free open source) to conduct as many dyno pulls as I'd like, and gave me the detailed specs and final ratio for a 2014 Si. All I had to do was enter additional weight, such as myself, and any other luggage I had in the car.
Car Specs entered are:
3rd gear pull
Tire Height: 25.09
Car Weight: 3150lbs (Amount provided by Steve, could be more or less)
Occ Weight: 235lbs (my weight + weight of a 10 inch sub)
Final Drive: 4.456 (provided by Steve)
Shown above is the graph using smoothing 6, smoothing 1 yielded 206whp/167lbft tq, however the graph looked slightly over-inflated, at least to my understanding it did.
Really happy with the results, my IAT were around 86-100 F. I'm sure on a colder day I would yield better results.
Mods:
PRL 3.5" short ram
rv6 catted
q300
3rd gear pull
Tire Height: 25.09
Finial Drive on our cars is 4.76
if you are still oem
I noticed that as well, however virtualdyno doesnt have a profile for the 2014 civic si, only the 2010 civic si. So steve did some math to make the final gear ratio match the car he's dynoing. He gave me the details on what to enter in virtualdyno amd I trust that the specs he gave me are accurate.
I do hope to get on a real dyno to see what numbers read on that.
Mods:
PRL 3.5" short ram
rv6 catted
q300
3rd gear pull
Tire Height: 25.09
Has anyone ever put one car on multiple dynos at the same place on the same day with the same conditions to show the different numbers between all the dynos?
Just did an e-dyno on my car and got 203hp and 179lbft of torque with 4.76 final drive.
Using the numbers above with the 4.456 final drive I got 234hp and 205lbft torque.
I don’t think the numbers add up. I think the final drive needs to stay at 4.76 to be accurate.
I'm going to do some more pulls when the weather gets better and try with the 4.76 final drive, because with the datalogs I have right now, If I use the 4.76 FD, I'm getting 162-168whp and 149tq, which is basically stock numbers, which I doubt I'm making.
Steve from Etunez also mentioned that the settings that I mentioned in my previous post are the settings that he uses to make the edyno match his own dyno.
I don't care if I'm under or over 200whp, I just want an accurate reading at this point lol.
Does anyone know what number Vit uses for his E-dyno results?
Okay so good news,
I emailed Brad from VirtualDyno to add the 2014-2015 civic Si in and he happily did within an hour! I'm getting a more accurate/realisitc amount of 193-195whp with the new settings, but I'm going to be redoing some datalogging. A
I had to provide Brad the specifications, so I did some researching and found these specifications for 14-15 Si's.
If you have more correct/accurate information, please let me know and I'll email Brad.
CarMake - Honda
CarModel - Civic
CarSubModel- Si
StartYear - 2014
EndYear - 2015
Weight - 3002
TransTypeManual - yes
TransGear3 - 1.429
TransGear4 - 1.073
FinalGearRatio - 4.76
DragCoefficient - 0.28
FrontalArea - 21.9
TireDiameter - 25.09
The settings that area in bold are settings that I'm not 100% certain on. There was a old post on this forum from 2012 saying the drag coefficient was in between 0.26-0.30, so I just did the median. As for frontal area, I believe that amount is for the 2010 Civic.
If someone who's dynotuned or edyno'd by Vit can verify that their results with these settings match the results they got from Vit/physical dyno
Cheers,
Did he say what smoothing to use?
