1 - 20 of 84 Posts
2012+ Honda Civic Si Ksport Kontrol Pro Damper System
Click here to see this product in our catalog and check out the most current pricing.
It’s been long overdue but the wait is finally over for the 2012+ Honda Civic Ksport Kontrol Pro Coilover. Features include: 7.5kg front and 7kg rear spring rates, 36 levels adjustable damping, front top mounts with camber adjustability, height adjustable lower mounts to maintain shock travel and of course they are backed by our industry leading 18 month warranty. MSRP is $1450. Fits all models. Contact one of our many dealers for pricing and availability.
Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts that allow it for the ability to adjust camber from the actual coilover, instead of a separate camber kit.
Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavatation are a lot less common in a Monotube design, which results in a better ride.
The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
Key Features
-36 levels of adjustable dampening
-Made from high quality 6061 aluminum with T6 for increased hardness
-Compression/Rebound adjustable
-Adjustable spring perch for height adjustment
-Adjustable body allowing maximum suspension travel
-Pillowball top mount with adjustable camber (not available for some models)
-Monotube high pressure design reduces oil leakage
-Electroplated body for protection from corrosion and rust
-One year limited warranty
If you have any questions you can reply to this thread, send us a pm or use the contact us page on our website.
Thanks for the continued support,
CorSport USA.
Anybody willing to buy a kidney? I NEED these coils!
Discussion Starter #9
Why?you do know k sport is cheap right?there not top notch and for the money far too much. For the low quality.
You'd be better off with s2 or d2 or bc or hfp or something name brand not eBay fame brand.just saying.
Ksport actually makes a good product especially for the price, this is not an ebay brand and is better quality then anything you will find in this price range... just sayin' ;)
Discussion Starter #12
Key Features
CorSport USA.
Discussion Starter #17
Key Features
1 - 20 of 84 Posts
